Results 1 to 5 of 5
Thread: RTACS on Main VE and Boost VE at the same time?
    Jan 2007
    Default RTACS on Main VE and Boost VE at the same time?
    Can you update the Main VE and Boost VE at the same time or do i need to just have one turned on at a time?
    The reason i ask, is when i have both enabled the 105 column on the boost VE table updates below 105... Does that make sense?
    I'm not sure, but it seems to mean that you can only have one table active at a time... (I haven't played with my RR sufficiently).
    Jan 2007
    Well i was able to figure it out. It took awhile. Basically you have to build a custom pID for each table. You also have to build in a MAP check to filter out MAP settings above/below the table boundaries. Once i get back to my laptop i will post up the PIDs if anyone is interested.
    I'm interested, please/thanks.
    Jan 2007
    I did a write up on PerformanceTrucks.net
    http://www.performancetrucks.net/for...6/#post5084192
  1. RTACS and boost VE?
    By DrX in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2014, 05:00 AM
  2. Main and Boost VE...one table?
    By hquick in forum Custom Operating Systems
    Last Post: February 20th, 2008, 07:10 PM
  3. Main VE and Boost VE looks weird
    By ForcedC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 19th, 2007, 01:20 PM
  4. LBZ Main Injection Pulse Time
    By JoshH in forum Diesel
    Last Post: May 10th, 2007, 10:04 PM
  5. Real-Time Automated Calibration System (RTACS)
    By GMPX in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 02:46 AM
