Results 1 to 3 of 3
Thread: Throttle Position readings
    Junior Member Strong05's Avatar
    Sep 2010
    Default Throttle Position readings
    I just made a simple diagnosis run on my brothers 06 I4 manual Colorado and noticed what I thought was an anomaly with the throttle position readings. Minimum TP was 12.2% and max was 89.4% at WOT. The only other throttle by wire system I've logged in is my LB7 (D-max) and it always shows 0% at idle and 100% at WOT throttle. So my question is: Is this the way it should operate or should I be seeing 0% at idle and 100% at WOT? If it's wrong could I have done something wrong with the EFI live scan tool/software?
    Thanks in advance for your help!
    Brad
    2000 WS6 T/A White M6, Mods: SLP Lid, Pro 5.0, LS7 clutch, QTP headers, LS6 intake, UMI: adj TA, BMR: LCA, STB, SFC, and adj PB. Best ET of 13.7 @ 107mph.
    You need to use a different PID, for ETC gas stuff there are (usually) 3 throttle position PIDs (well 2 plus accelerator pedal position). Im betting you're using SAE.TP, validate the PIDs again then see which of the GM.ETCTP PIDs shows up as supported for it. Try logging with that.
    It will never show 0% TPS because on DBW vehicles the throttle is never fully closed except when the engine is off. DBC vehicles go to 0% TPS because the IAC allows enough airflow for the engine to idle, ETC setups open the throttle blade slightly to accomplish the same thing.
    Sep 2010
    Thanks Erik! I was afraid I might have been overlooking something. I'll re-verify the pids and re-log.
    Thanks,
    Brad
  1. Throttle Position
    By bstuder11 in forum Gen IV V8 Specific
    Last Post: April 8th, 2012, 12:12 AM
  2. Throttle position Pid
    By zbadestz in forum General
    Last Post: February 26th, 2012, 01:52 AM
  3. Throttle position confuddlement
    By turboberserker in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2010, 07:18 AM
  4. Absolute Throttle Position
    By mvnvltn in forum General (Petrol, Gas, Ethanol)
    Last Post: December 29th, 2008, 10:22 PM
  5. Throttle position 256%
    By vatman02 in forum General
    Last Post: September 27th, 2007, 06:08 PM
