Page 1 of 9 123 ... LastLast
Results 1 to 10 of 82
Thread: Looking for some pointers on maf tuning.
    Member TJWells's Avatar
    Apr 2008
    Default Looking for some pointers on maf tuning.
    I've gotten some excellent help tuning my vve, now i need to tune the maf I think. read through the tutorial and I gotta admit I'm lost.
    My vve table is really good, I think. I have all 1's in my ben table. When I reconnect the maf and reverse what I did to log data per tutorial I see a few .9's in the upper RPM's. What should I do to tune the maf?
    Set the dynamic air transition RPM to below idle (i.e. the RPM at which MAF+VE transitions to/from pure MAF)
    [ sorry, I don't have a file in front of me at the moment to quote the table id ]
    and then use wideband BEN to correct the MAF table.
    swingtan
    Guest
    Joe is talking about {B8024} and {B8025}. Set them to something like 500 and 400 RPM and you should only be running in MAF measured airflow.
    Simon.
    Apr 2008
    Thanks guys,
    I assume I log ben while running on just maf then adjust maf accoringly?
    Quote Originally Posted by TJWells View Post
    Thanks guys,
    Yes, MAF only, running in OL (to avoid CL/LTFT/STFT trimming).
    Apr 2008
    Thanks joe, i would have worked in closed loop had you not mentioned that.
    Cuz I miss the simple stuff all the time!
    Apr 2008
    What table does the ecm look at to determine what afr should be?
    Lambda=AFR / Stoich where does it get what stoich should be?
    Also why don't we do anything with CFCO for logging BEN? We turn off DFCO.
    Commanded fuel is determined as follows:
    PCM determines commanded EQR from:
    - CL: closed loop feedback trimming to stoichiometric (EQR 1.000),
    - OL: the richest EQR from the EQR tables active at that moment:
    -- B3605 (OL only) (see note below),
    -- B3647 (OL only) (COS) (see note below),
    -- B3618 (if PE has enabled from B3608-B3616, B3619-B3626),
    -- B3659 (if PP has enabled from B3652-B3658),
    -- B3603 (if EP has enabled from B1601-B1603),
    -- COTP (if COTP has been enabled by B0701-B0705) (I don't see a table for COTP EQR).
    More info, see post #4: Summary-Notes
    B3601 defines the stoich AFR to the PCM.
    Actually, it's defined the other way round: AFR = stoich * Lambda
    (i.e. AFR is defined in terms of Lambda, Lambda is the same for all fuels)
    The wideband either has a programmable stoich AFR (e.g. LC-1/LM-1/LM-2) or assumes some value (e.g. NGK assumes 14.5);
    if you use wideband Lambda then you don't have to un-factor stoich AFR out of the correction.
    When DFCO kicks in it makes a rapid/step transition to DFCO fueling...
    there are several reasons for disabling DFCO during tuning:
    - want to avoid large fueling transitions (we're already dealing with airmass transitions),
    - if DFCO AFR/EQR is not reflected in the commanded fuel pids.
    You can still tune with DFCO enabled, your transient filter will now have to include a clause to filter it out.
    Apr 2008
    I understand why DFCO just curious why CFCO isnt an issue.
    Since CFCO does same thing as DCFO (but in context of manual transmission clutch), it probably should also be disabled during tuning.
  1. Tuning changes going from 85mm MAF to LS7 or other 100mm MAF?
    By PRAY in forum E37, E38 & E67 PFI ECM's
    Last Post: November 21st, 2012, 02:11 AM
  2. timing pointers. . .
    By truethinker in forum Gen III V8 Specific
    Last Post: June 25th, 2012, 04:23 AM
  3. 2005 silverado 5.3 need some tuning pointers
    By whiteboy631 in forum Gen III V8 Specific
    Last Post: December 22nd, 2010, 10:00 AM
  4. New to EFI need some pointers plz
    By shadyst in forum Gen III V8 Specific
    Last Post: November 24th, 2009, 04:58 PM
  5. Stock maf = perfect idle. Big maf = unstable idle. Any tuning suggestions?
    Last Post: July 11th, 2006, 03:58 PM
