Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Few tuning questions
    Aug 2012
    Btw this was a maffles tune i bought with a pcm
    so havent gone through everything.
    The tuner i used previously had locked my pcm
    So i just got another one and sold my original.
    At the time it had stock,tb,injectors and small 1-5/8 primary pipes
    same cam and heads etc.
    Aug 2012
    Found the crank angle sensor issue,
    The harness was squashed between the block and heat shield
    against the headers,exhaust shop must have done it
    when i had the 4 into 1s installed ,been like that for a while too.
    Just repairing the harness now.
    see my responses in red:
    Quote Originally Posted by VX-SS-383 View Post
    A0009 Boost VE doesn't seem right (and looks too smooth).
    *Didnt realise anything was there,does it even use this table?car is n/a
    If you don't have boost then ignore A0009.
    B3618 is too restrictive above 3200 rpm... set that portion to 35%.
    *Might seem silly but what do you mean by 35%? set it 35% higher or lower?
    The table is TP with units %... above 3200 rpm set it to 35% (look at 2002 Camaro file for example).
    *Ive fixed everything else that you mentioned.
    With the spark map im pretty sure it only uses the low octane map
    any when your mafless? i just modded the high octane
    and made the low octane identical or should they be different?
    COS's enable adaptive spark when MAF-less (i.e. spark timing slides between HO and LO tables according to presence/intensity of knock).
    I also did a log and P0336 came up crankshaft position sensor,its missing quite bad under 80-100% throttle.
    Ive attached a log,couldnt really give it much it would just break down
    and throw the cel on.
    I'll take a look at your log later tonite.
    Take a new log.
    Aug 2012
    Thanks joecar,i fixed the missfiring issue.
    All good now,so i can sought out the tune now.
    Ill load those changes and get another log today.
    Ok cool let us know how you go.
    How did you fix the damages CKP sensor harness...?
    Aug 2012
    Removed the heatsheild completely as it wont fit properly
    with the huge 1-7/8 4 into 1 headers- ceramic coated headers anyway.
    It had just cut the insulation enough to ground out on hard acceleration.
    Used some electrical tape and flexable conduit to insulate it.
    The old conduit just crumbled away.
    Very happy i found it and fixed it for $10.
  1. new to tuning questions
    By dwessels in forum Gen III V8 Specific
    Last Post: March 25th, 2012, 06:25 AM
  2. Tuning questions..
    By 68showngo in forum Cummins 5.9L
    Last Post: June 6th, 2011, 04:52 PM
  3. LTFT tuning questions
    By stevedarman in forum General (Petrol, Gas, Ethanol)
    Last Post: January 2nd, 2010, 08:54 PM
  4. PE tuning procedures/questions....
    Last Post: February 12th, 2008, 12:03 PM
  5. Tuning VE Questions??
    Last Post: April 23rd, 2005, 07:47 AM
