Results 1 to 10 of 18
Thread: Custom os tuning questions
    Aug 2011
    Default Custom os tuning questions
    I’m going turbo this year and I changed over to COS 3 in Efilive and now im lost. They talk about Semi open loop and now tuning via PE or boost ve. Help me out here, I’m running O2 sensors still and I’d like to use them but it seems like I would be better to disable PE altogether and just tune off of the ve and comanded tables. Also in COS 3 they now change to commanded rpm vs map which is blank from the re-flash, should I populate this table from the previous commanded table (if thats possible)?
    Feb 2008
    You need to take the values in the 105kpa column and copy them exactly to the 105kpa column in the boost VE table. Then you have to fill in the remaining VE boosted table cells with #'s. Once your over 105kpa your basically using the VE # as the actual fuel value for fueling. So if your logging and the air/fuel is 13.5 take the cell value and multiply it to get your desired (11.5'ish) value.
    In semi-closed loop the O2 sensors are used still to regulate to the stochiometric value you have listed in the table B3647. The long term fuel trims are no longer used (disabled), so monitor short term fuel trims to see what the VE table is doing. I disable PE completely and then modify the Boosted VE table for my desired air/fuel levels.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    Feb 2012
    There are a few tables that are blank when first going COS, have a read of the Custom OS Tutorial in the TuneTool - it covers of setting up the new tables.
    One approach to fuelling is to use B3647 to control up to 105kPa, then use PE as BE above say 120kPa, as described by johnv in THIS post.
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Quote Originally Posted by cyipher View Post
    Quote Originally Posted by darcy View Post
    The tutorial had commanded set at 1 all the way until 100kPa then richened it up. You're saying that is correct? Unless I'm missing another commanded fuel table or multiplier somewhere, that sounds dangerous to run 1 EQR(14.7:1) at 70kPa at 5000 rpms. I set the commanded to where I think it should be, not at 1 as explained in the tutorial.
    +1 set B3746 to sensible values, especially if PE is disabled...
    ( I would also leave PE enabled )
    [ please, don't blindly follow the tutorial... think about what is going on and how it works ]
    In OL, the cells in B3647 set to EQR 1.00 will be trimmed on using STFT (even if CL/trims are disabled)... this is called Semi-Open Loop (SOL);
    during tuning you have to watch out for this (do not use EQR 1.00 in B3647... use 0.99 or 1.01 instead).
    Jan 2007
    That's why the question was asked. And that is why I didn't do it haha. I think they may change that or note the the tutorial so someone doesn't miss that.
    Even with the CL temp set to max and STFT disabled? Not that there is an issue with that at all, it's definitely great info to know(remember). Just wondering why it does that when it's set up not to...
    Also does the commanded table for ethanol B3649(maybe)??? need to match b3647?
    Quote Originally Posted by picnic_george
    Yes, even with CL disabled (CL temp set to max), LTFT disabled, and STFT disabled.
    SOL is enabled in OL for any stoich cell in B3647 or B3649.
    B3647 and B3649 do not necessarily have to be the same...
    Aug 2011
    so whats the difference in SOL and CL with LTFT disabled then?
  1. 3bar custom OS questions
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2006, 03:33 PM
  2. Custom OS questions from a new tuner
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 02:00 AM
  3. two 3 bar custom OS questions.
    Last Post: September 16th, 2005, 09:45 AM
  4. Questions about swaping from 99 OS to custom 01 OS
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 09:49 AM
  5. Questions about upgrading 99 OS to Custom 2001 OS
    Last Post: September 12th, 2005, 04:55 AM
