Results 1 to 8 of 8
Thread: Spare cables?
    Dec 2010
    Default Spare cables?
    I need both cables for a V2 so I can remove the V2 from it's semi permanent position in my vehicle to use in others.
    Do they make a ALDL plug cable at 45 degree yet? Or way to build one?
    You can see why I want 45 here...
    EFILive doesnt, you can buy an OBDII extension that has a 45* on it though I imagine.
    If you want spare cables, you're best bet is to talk to a reseller/distributor in the US.
    May 2013
    unscrew one of the screws that hold the OBD2 connector on and spin it 45 - 90 degrees.
    Quote Originally Posted by phonedawgz View Post
    No, he means 45 degrees in the vertical plane of the cable (so the cable hugs the dash before it goes over the steering wheel).
    Nov 2011
    Got me thinking so I checked out e-bay. Is this what you were thinking of? (Last time I tried linking I got hit with the auto spam bat so here goes nothing...)
    http://www.ebay.com.au/itm/16Pin-Mal...23abb73&_uhb=1
    http://www.ebay.com.au/itm/16-Pin-Ma...bb4b7d8&_uhb=1
    http://www.ebay.com.au/itm/New-30-cm...72ab87e&_uhb=1
    http://www.ebay.com.au/itm/OBD-II-OB...7a14406&_uhb=1
    Dec 2010
    Well that's a good thought, but then I have more extra cable and another connection. Just more crap that I don't need.
    Since I need a spare set of cables I just thought I'd ask if there is a 90* EFI Live cable...
    Not that I know of.
    Jul 2003
    You can make one...buy one of those 90 degree cables and crimp your own... it uses an rj45 male terminal.
    I've fixed mine over 20x and it is super simple.
  1. Spare ECM?
    By Steve Hayes in forum General
    Last Post: September 21st, 2010, 01:56 PM
