Quote Originally Posted by EagleMark View Post
Button options says: "Execute from PCM flash memory if fitted, else execute from RR?" So I tried and it will not flash through V2, looks to be locked?
You should never attempt to flash the RR using the V2 - it won't work, its not supposed to work.
The RR should only be programmed using its direct USB connection and the RR Control Panel in the EFILive software.
