Results 1 to 10 of 13
Thread: Segment swapped by HPT....won't read with EFIL
    Redline Motorsports
    Guest
    Default Segment swapped by HPT....won't read with EFIL
    I'm assuming that the reason why EFIL won't read this LS1 controller is because it has a segment swapped cal by HPT. Its using a Vette OS but the platform is still the truck. If I flash it with a stock Vette auto OS it should allow me to read it with EFIL and start over with an EFIL segment swap......yes....no? Joe??
    Did HPT lock the PCM...?
    Heck if you can flash it (ie its not locked), then there's no reason to even read it out again unless you want to verify everything.
    Can you get PCM details using V7.5 to see if it's locked? The seg swap shouldnt matter, it sounds like the PCM is locked.
    Redline Motorsports
    Guest
    It finds the unlocking seed but fails the bootloader....
    Its a valid OS but what I was wondering was if EFIL looks at all the segments to see if they are the ones that belong with that OS
    I sent a message to Paul.
    Nov 2007
    did you try v8? There was a bug in recent release where v7 would report failed bootloader. May 20 Update has the fix.
    Quote Originally Posted by Redline Motorsports View Post
    ]Its a valid OS but what I was wondering was if EFIL looks at all the segments to see if they are the ones that belong with that OS
    No not at all, we don't even care if there is no VIN in there, it should just read out whatever was in there and away you go. I suspect kangsta's suggestion might be the answer.
    Redline Motorsports
    Guest
    Quote Originally Posted by kangsta View Post
    V8 does it again!
    V8 does it again!
    Told ya you need to get familiar with it! Now flash a few times with V8, dare you to go back to V7.5...
    Except it's an LS1 PCM, VPW is still slow no matter what you are using, CAN is a different kettle of fish.
  1. V2 won't read
    By rulonjj in forum FlashScan V2
    Last Post: January 3rd, 2013, 03:04 PM
  2. Had to use hpt as efi couldn't read
    By auspeed in forum Gen III V8 Specific
    Last Post: September 1st, 2012, 11:11 AM
  3. tps won't read 0%
    By steve40 in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 12:56 PM
  4. Anyway to read a HPT file?
    By turboolds in forum FlashScan V2
    Last Post: December 16th, 2008, 08:17 PM
  5. 2000 gmc seirra 4.3 won't start after attempt to read pcm!!!
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 20th, 2005, 01:58 PM
