Any one know why my v2 would log or do anything when it's hooked up to a vehicle? I've tried different vehicles and I get the same error. It used to work but now it doesn't after the update. Here is a pic I've updated everything and it shows I did.
[/SIGPIC]
2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
After you flashed in the latest firmware into your V2, did you do BBx Program All...?
How do you do that?
[/SIGPIC]
Everything that I know of is up to date.
[/SIGPIC]
Okay ill check as soon as I get home. Another question I've got a buddy that has the same thing kinda. He also said he has updated everything. This is what his says when he try's to log his truck with the laptop connected.
[/SIGPIC]
I selected my control and programmed it but it won't let me watch anything off the v2 like it used to. Like balance rates and all that.
[/SIGPIC]
I can't find program all on my drop down?
[/SIGPIC]
