Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 02 Silverado Tune Help
    Member ippielb's Avatar
    Jun 2010
    Default 02 Silverado Tune Help
    2002 silverado with a 5.3l engine, flex lite electric fan, cold air intake, throttle body spacers, iridium tip plugs, long tube headers, cats removed, 35" tires, 4.56 gears.
    I keep burning front 02 sensors, can't seem to stop it.
    Exhaust smells rich, and you can mainly always see the humidity from the exhaust like it's cold out.
    truck feels gutless in mid range.
    Here's my tune, rip it apart, the more you criticize it the better.
    02 Silverado Sept 1.ctz
    2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    NADP Race Transmission & NAPC Built Transfer Case
    AFE Stg 2 Intake Snow Performance Methanol Injection
    FASS 150gph Titanium Series Pump EFI Live
    PPE Race Valve & PPE Fuel Rail Fitting
    BD Manifold 3" AFE Ceramic Downpipe 4" Straight Pipe
    Yukon Grizzly Locker Mag-Hytec Cover & Traction Bars
    Leveling kit & 33" Hankook RT03 18" XD Addict Rims
    HID's all around LED taillights and 3rd brake light
    Autometer Fuel Pressure, Boost, and Pyro Gauges
    Mar 2009
    Are you sure it isn't burning coolant?
    Jun 2010
    Quote Originally Posted by Big Mike View Post
    100% sure it's not coolant. Smells like fuel, doesn't smell sweet, exhaust is dry. It running rich.
    Plus it has been doing this for a LONG time, and haven't had the coolant drop at all. Not just a recent thing, i bought a new duramax and have kind of neglected this truck. Just getting back to finish the job.
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Would help if you posted up a log. Also, that is not a valid tune file - not sure what you posted...
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
    Jun 2010
    Quote Originally Posted by BLK02WS6 View Post
    It's a ctz file for putting onto the controller so I can put the tune into my truck without having to use the laptop.
    What would you like me to log I will go make one right now.
    Jun 2005
    Default metric pids would be good. Can ctz files be converted back to .tun files to view on a laptop? I never use them, so don't know...
    GM EFI Tuner
    Jun 2010
    I just open up the ctz file on my tune tool, opens right up like a .tun file does. Let me know if you need the .tun file. I will get it from my truck when i get back to the farm. In tractor right now.
    Jun 2010
    LS1B_0002.efi\
    heres a log i dont know if its what you guys needed.
    Jun 2005
    Here are the pids in the default metric group (ignore the x's). That is what we need to see. Mainly wanted to see LTFTs, but other things in there too... Click image for larger version.
Name:	default metric.JPG
    GM EFI Tuner
    Jun 2010
    heres the one with defaults pid
    LS1B_0003.efi
    Driving it right now seems like it had more balls, maybe it finished it's learn process after the new intake manifold and knock sensors. but still has that dead spot mid range and doesn't like to accelerate unless it has more rpm. Needs a little help on idle. Idles a little low and has the shakes.
    Also one other thing, i have the flexalite dual electric fans, it has the variable speed controller on it, i see on my EFI live there is some spots where you can tune in an electric fan like on the new silverado's. Just curious what wiring would need to be changed, is there a kit? I have burned two controllers from flexalite for no apparent reason. I'm ready to keep them on the shelf and use the ECU to determine when the fans come on.
  1. Help with Silverado tune
    By nfs13b in forum Gen III V8 Specific
    Last Post: May 15th, 2012, 10:17 PM
  2. Can I tune my 06 Silverado with my V1?
    By PRAY in forum Gen III V8 Specific
    Last Post: March 25th, 2009, 05:19 AM
  3. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  4. silverado 06 tune
    By way2much_01 in forum Gen III V8 Specific
    Last Post: November 20th, 2007, 07:53 PM
  5. SS Silverado tune
    By Boost in forum Gen III V8 Specific
    Last Post: June 21st, 2007, 01:25 AM
