Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 58
Thread: Trouble With CalcVET
  1. #31
    Mar 2013
    screen shots
ID:	15413   Click image for larger version.
    99 Hugger Orange Z28 - Crate LS6, Bolt-ons, TSP Long Tubes, Borla/QTP, Ram VDS Sintered Iron, Stage 2 T56, Mcleod Master, MWC 9", Strange Pro HD Aluminum, 4.30s, Spool, BMR Subframes - 11.30 @ 121.65
  2. #32
    Screenshot of your scantool map populated with the BEN...
  3. #33
    Mar 2013
    my wo2 reading at idle moves around alot. 14.7-15.2 but the LTFT dont respond when it jumps up a little lean. not sure if thats normal
  4. #34
    Map looks good... those spikes and sinkholes in you VE should not be there, flatten those out... I'll take a closer look at your log/tune files today (I'm on a MacBook at the moment)...
    post your calc_pids.txt file also (it makes it easier to view your logs with your calc_pids.txt just in case it is different than mine).
  5. #35
    Mar 2013
    yeah idk why i keep getting those huge spikes. i posted my calc_pids on page 3 with my log file and pids file
    I setup two more tables of my own just for the hell of it. maf freq vs map & rpm and lamda vs map & rpm. because i feel my calculated VE table is kinda all over the place.
    Im hitting 10500 Hz @ wot (gm 85mm maf) 329 g/sec, moving alot of air for a bolt on ls6?
  6. #36
    Mar 2013
    heres a log i did after i changed the maf curve a bit
    Log_0014.efi
    previously i had to command 11.3 to get 12.5-7 afr. the wot afr i got after changing the maf table was 11.9 to 11.47
  7. #37
    Are you applying the transient filter...?
  8. #38
    Mar 2013
    yeah but it still doesnt always make sense, highs and lows.
  9. #39
    Mar 2013
    im trying to dial in the idle but it seems no matter what i do the computer just does what it wants. i can get it to idle around 14.7 then turn the trims back on and it starts pulling out 5 percent fuel. is it normal for the LTFT to be removing fuel while the STFT are adding?
  10. #40
    Quote Originally Posted by SLP IROC-Z View Post
    Yes, that is ok...
    how it works: STFT moves up or down, if they exceed some threshold (positive or negative) then the LTFT get bumped in that direction and the STFT gets reset to zero... after STFT is zeroed it can now start moving up or down again (i.e. could be in opposite direction from LTFT bump).
  1. 1998 calcvet. pid list
    By bbaird in forum Gen III V8 Specific
    Last Post: July 1st, 2013, 10:23 AM
  2. CalcVET Question
    By BlackSS in forum Gen III V8 Specific
    Last Post: December 9th, 2011, 02:49 PM
  3. Tuning Trouble???
    By ws6fitz in forum Gen III V8 Specific
    Last Post: March 19th, 2009, 05:44 PM
  4. Having trouble with E-Explorer
    By Tony @ MPH in forum FlashScan V2 BB Logging
    Last Post: January 3rd, 2008, 03:34 PM
