Results 1 to 10 of 15
Thread: Go back to original operating system?
    Oct 2008
    Default Go back to original operating system?
    How do you go back from a COS 3 to the original operating system? Do not have the tune file for the original operating system. Can i flash a tune with the original operating system then do a enigine and transmision segment swaps?
    99 ECSB, LS6, 224/228 .609/.588 110LSA, 4L80E, PI 3800, 4.10, Truetrac, Caltracs
    10.67 @ 96mph 1000' pass http://s265.photobucket.com/albums/i...JayvsJerod.flv
    BAD BOYZ RACING
    KK PERFORMANCE
    You can full flash the base OS, then do a cal-only flash from the latest COS file...
    e.g. 02020003 is based on 12212156.
    Feb 2008
    Quote Originally Posted by bad boyz racing View Post
    Yes, I've done it before when people went back to mostly stock. Just find a tune file with the needed os, perform a full os flash it in of the gm system, then do a same os trans segment swap and your golden.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    You can full flash a base tune having the same transmission...
    or you can full flash a base tune with a different transmission and then do the transmission segment swap...
    you will still have to do a cal-only flash from the COS file to get the modified tables into the stock tune (and you then also have to edit B3605 back to stock).
    Jan 2010
    I have loaded COS5 successfully but now I want to revert back to the original 12212156 OS. But when I load my last tune file (the one with 12212156) the option to flash PCM and OS is grayed out. I have the commercial scan & tune version.
    Plug your FlashScan into your laptop prior to opening any tune file, then you will have the full flash option available. If you have a V2, Id suggest using V8 to flash.
    Jan 2010
    That worked, thanks!!!!
    Quote Originally Posted by tinindian View Post
    Sure thing.
    Yes, absolutely no reason you cannot, as long as the base OS is correct.
    +1 no problem.
  1. Different Operating System ?
    By 1stGlance in forum General
    Last Post: August 15th, 2012, 08:22 AM
  2. change the operating system
    By cainer70 in forum General (Diesel)
    Last Post: March 30th, 2010, 02:19 AM
  3. 02 operating system?
    By THEFERMANATOR in forum Allison 5 & 6 Speed
    Last Post: October 25th, 2009, 12:58 PM
  4. Going from 00 to 02 operating system
    By lastcall190 in forum Gen III V8 Specific
    Last Post: November 12th, 2007, 04:50 PM
  5. operating system
    By ls1transam346 in forum Gen III V8 Specific
    Last Post: February 22nd, 2007, 11:49 AM
