Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: CSP5 DATA LOGgING INOP
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Question CSP5 DATA LOGgING INOP
    Has anyone had problems data logging with CSP5? I can use EDA using bbl and I can change tunes.
    Nov 2010
    Default CSP5 DATA LOGgING INOP
    What's the problem?
    BBl sounds like it works...
    Sent from my iPhone using Tapatalk 2
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    [email protected]
    www.youtube.com/ljszmidt
    Jun 2013
    I cant look at live date using v7.5 or v8. Using scan 7.5 it wont let me select the EDA pid group.
    May 2009
    Quote Originally Posted by garrettg.bpd View Post
    any news on this I cannot select the EDA PID group either
    Nov 2005
    Just make sure you've followed the guide to select the EDA PID group, and at what point does the scan tool perform functions not as described in the document?
    Live scanning should be functional in V7.5 however this function is not available in V8.
    Cindy
    Nov 2010
    Cindy,
    I can verify scan tool operation in pass-thru this afternoon after work, I'll post my results.
    Les Szmidt
    2007 5.9 Dodge Ram
    [email protected]
    Nov 2005
    Thanks Les,.
    Cindy
    May 2009
    My truck has Csp5 installed and I use v2 to switch tunes that works and I have verified that. In v8 I checked the box to reload previous pid group the named my tunes selected CMB pid list per the guide clicked and drug the pid sub folder EDA1 to the box on the left per the guide and selected program all. initially got a "write failure" error code but after formatting it programmed all. Then it would switch tunes and everything but the only time I can select the EDA Pid group in v7 scan tool is if I uncheck the box for supported then I can select EDA but all pids are invalid. This is with v2 connected to truck with csp5 and laptop before starting v7. I did load the tune in the truck befor configuring v2 for eda and haven't flashed since
    With setting up V7.5 are you absolutely 100% sure you are following the user guide exactly as shown under "Data Logging with V7.5 Scan Tool", page 15?
    In V7.5 scan you might also try to force PID revalidation when connected to the truck (press Shift + F2).
    May 2009
    I clicked on the validate pids icon and bingo it worked otherwise would not allow me to select. I guess I was just spoiled with the software always doing it for me!Click image for larger version.
ID:	15582Click image for larger version.
  1. Data logging help!
    By 05longbed in forum AutoCal
    Last Post: November 27th, 2013, 12:18 PM
  2. data logging
    By Gwoody in forum Cummins 5.9L
    Last Post: December 1st, 2012, 09:31 AM
  3. Data Logging NEED HELP
    By dodgeram5-92500 in forum Cummins 5.9L
    Last Post: August 23rd, 2012, 11:39 PM
  4. Data logging
    By dannyperform in forum General (Diesel)
    Last Post: June 21st, 2012, 04:45 AM
  5. V1 Data logging
    Last Post: December 2nd, 2007, 07:01 PM
Tags for this Thread
