Page 4 of 14 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 139
Thread: 600 rpm slip limit solved!!!! OS 25941752
  1. #31
    Feb 2012
    Sounds good,
    Thnx
  2. #32
    Apr 2012
    I would like to try your modified tune. Here is the tune I am currently running in my 08.
    2015 Chevy 2500 DC 4x4 LML Stock w/EPA friendly tuning.
    2008 GMC 2500 CC 4x4 LMM DSP-5, Transgo Jr,Converter Flow Valve, Sun Coast Triple Disc,4'' Exhaust,Lift pump,Edge Evo for the gauges.
    2006 Chevy 2500 CC 4x4 LBZ Built Engine, Built Trans, Goerend R, S475/Stock, 30% over injectors.
    South of the Rio Grande
  3. #33
    Senior Member Quinton's Avatar
    Apr 2013
    Default 600 rpm slip limit solved!!!! OS 25941752
    Any updates on the 5 speed TCM?
    [/SIGPIC]
    2005 duramax LLY, 12.75 on stock motor/fuel, 68mm vgt built trans.
    Built motor by me, built trans, EFIlive by me, dual fuelers, 80% injectors.
  4. #34
    Mar 2013
    Quote Originally Posted by BigTexas68 View Post
    Would your tune work with my 07 8.1 os how is the closed throttle down shifts.
    thanks for your info
  5. #35
    Jul 2011
    Gotta bump this! Any more progress? I know a lot of people including myself that would love to be able to get into these tables
  6. #36
    Junior Member hondarider552's Avatar
    Apr 2008
    X2...
    03 single cab work truck LB7- 11.95 @ 113
    06 crew cab lowered Colorado.
  7. #37
    Nov 2005
    Modifications have been made. We just need to regenerate the cal files and include them in the next beta release. Once tested they will move into a public release.
    Cindy
  8. #38
    Jul 2011
    Cindy
    even for 5 speeds or only 6 speeds?
  9. #39
    Jul 2011
    will it be included for the 5 speeds as well or only the 6 speeds?
  10. #40
    Mar 2009
    Quote Originally Posted by chevy1925 View Post
    What he said. I would like to get lockup in 2nd instead of waiting until late in 3rd or 4th.
  1. 600 rpm slip limit
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: December 2nd, 2012, 07:00 PM
  2. Fuel and RPM limit question...
    Last Post: June 2nd, 2010, 11:56 AM
  3. speed/RPM limit cancel!!
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2009, 05:44 AM
  4. RPM limit
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 7th, 2008, 05:41 PM
  5. High RPM power loss solved
    By PSWired in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 16th, 2005, 12:43 PM
