LBZ is identical to the LMM with respect to turbo brake tuning. Also, there is no way to turn it on ONLY while in T/H, however, there is a way to cheese it. Under normal driving conditions (cruise braking) the engine typically won't go above ~2000-2100rpm so you can close the vanes down in 0-5mm3 and above 2000rpm and without T/H the turbo won't close down.
