Results 1 to 7 of 7
Thread: 2008 LMM Transit Bus
    Jun 2011
    Default 2008 LMM Transit Bus
    Does anyone know if this ecm is compatible with efilive. i have a customer who is wanting tuning but before he drives the distance for me to put dsp5 on it he would like to know if it is supported. looks like other lmm ecm's let me know if you need any other info. thanks.
    Mar 2009
    The ECM is probably the same, but need to know the operating system loaded in it to see if it is supported or not. There are a few out there that I don't think are supported that GM released to some offroad companies. If it is just a MD truck then chances are it is supported.
    Just before he takes the drive you should be made aware that those 'non truck' applications sometimes use specific 'non truck' OS's, most of these have not had DSP5 written for them. The OS 12620015 is often used in Motorhomes and all 5500 based vehicles, this does not have a DSP5 upgrade option. Normal tuning is possible, just no DSP.
    Jun 2011
    Quote Originally Posted by THEFERMANATOR View Post
    Thanks. I'll let him know
    Jun 2011
    Does any of this help you to clerify support Ross? The dealer has no clue what an OS is and i have no clue how to read Tech II. Im assuming OS = Calibration ID
ID:	16053Click image for larger version.
ID:	16054Click image for larger version.
ID:	16055Click image for larger version.
    That is the same OS the Express Van uses (12628740), normal tuning is supported, but there is no DSP upgrade.
    Jun 2011
    Thanks ross
  1. Lmm 2008 Savana Support?????
    By johnj in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 30th, 2013, 12:19 PM
  2. 2008 LMM DSP5 switch not working.
    By drthv8r in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 17th, 2012, 01:42 PM
  3. P0606 stalling engine on a 2008 LMM
    By Mitco39 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 6th, 2012, 04:12 PM
  4. 2008 C5500 LMM Idle timer?
    By dieknow in forum Diesel
    Last Post: June 15th, 2010, 08:00 AM
  5. 2008 LMM support?
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2007, 11:56 PM
