Page 7 of 9 FirstFirst ... 56789 LastLast
Results 61 to 70 of 84
Thread: Calc.MAFT: correcting VE and calculating MAF (in single log) --> reverse of Calc.VET
  1. #61
    Quote Originally Posted by voda1 View Post
    Link does not work - shows:
    vBulletin Message
    Invalid Attachment specified. If you followed a valid link, please notify the administrator
    See post #1 for the latest calc_pids.txt file.
  2. #62
    Aug 2013
    gday all just trying just trying to set up my pids list and when it comes to the calculated maf pid all i seam to have is a calculated maf,not corrected.yet it is not supported by my pcm.im running os 01290005 osid v5.how will this affect doing calc.maft.
    thanks
  3. #63
    Do you see the pid CALC.MAFN...?
    Does it have a red thru it...?
    On the PIDs tab, click on the column titled "Parameter" (to sort the pids by this column), and scroll down until you see CALC.MAFN and CALC.MAFT...
    if either of those have a red X, then do rightclick->More Info to see which other pids need to be selected.
  4. #64
    Aug 2013
    thanks for the reply joecar
    right click did the job i had to add
    dynamic air temprature from the tuning system calc.dat
    i had dynamic air temprature from the tune system gm.dyncylair_dma.
    it seams to work now.time to log.
    thanks again.
  5. #65
    Ok cool
  6. #66
    Feb 2016
    I tried to use those PIDS but it does not allow me to do it as I think it is an old version of EFI live. Am I doing something wrong or does it need to be updated?
  7. #67
    Quote Originally Posted by oreobadr View Post
    Which V7 build version...?
    Do you have V1 or V2...?
    Which year/model/vehicle...?
    Post some screenshots showing what is going on.
  8. #68
    Feb 2016
    I have a V2, its a 2002 pontiac Trans am, and its the V7.5. Its when I download the PID text file and try and open it in the tuning tool, there are no PIDs present. Also, when I try and add the PIDs by myself some of the PIDs are not there to add.
  9. #69
    Junior Member CHEVYHD496's Avatar
    Jul 2011
    Ok, please go easy on me as I'm new to this! When you say "disable maf", how do I disable it? Then I do not have a WBO2, so can I then still use this setup to tune? Thanks!
    02' Chevy 2500HD 496/Ally,EC/LB,4x4,3.73,AirRaid CAI,180' t-stat,Comp Cams 1.72:1 Roller-Tip rockers,SW 1 7/8 LongTube Headers
    BBK TB back in the box-for now
    New 8.1 with Raylar heads: build in progress
    U.S.M.C.
  10. #70
    Did you copy the calc_pids.txt file ti the folder User Configuration...?
    Did you name it calc_pids.txt...?
    In the scantool, on the PIDs tab, click on the column heading of the right hand column to sort by tbat column, scroll down, look for those pids, do you see them...?
    ~ posted by phone ~
  1. Calc.VET: correcting MAF and calculating VE (in single log)
    Last Post: February 20th, 2023, 04:55 AM
  2. CALC VET Summary Notes
    Last Post: August 28th, 2014, 07:49 PM
  3. CALC. VE Table help
    By nchristian in forum Gen III V8 Specific
    Last Post: January 28th, 2011, 09:18 AM
  4. RPM Threshold for Airflow Calc {B0120}:
    By Mark300 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 2nd, 2009, 01:40 PM
  5. Startup Friction Airflow Correction table?
    By jnorris in forum General (Petrol, Gas, Ethanol)
    Last Post: November 10th, 2005, 05:01 PM
