Results 1 to 3 of 3
Thread: Can't log to sd card
    Default Can't log to sd card
    I feel I've read every post here. I'm sure I missed it though. I can't seem to log to the sd card. Everytime I hit "record data" I get a error "file not found" I can connect & watch it but it will not go to the card. I have the latest EFI updates (Installed & reinstalled) Formated the card a few times. It's driving me cazy.
    Any ideas?
    Thanks,
    Todd
    2004.5 GMC K2500 6.6- The Puller
    2005 Chevy K3500 6.6- The Tow Truck
    2003 Chevy K1500 5.3
    1987 Chevy Blazer with a 6.2
    2010 TDI Jetta
    1997 Chevy K1500
    Did you format your SD card...?
    Did you do this (see post #1): Setting-up-a-FSV2-from-scratch
    swingtan
    Guest
    1. Ensure the lock tab on the SD card is not in the "write protect" location.
    2. If all else fails, format the SD card in the V2.
    Normally, you only need to create the required directory structure, but recently I've found I had to format the SD card in the V2 to get it to work. I'm not sure why as the directories were there, but I'd manually created them via the PC.
    Simon.
  1. Q about SD Card usage w/V2
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: November 19th, 2011, 11:01 AM
  2. sd card saving???
    By 2004gmc in forum Lounge
    Last Post: May 9th, 2009, 03:18 AM
  3. SD card
    By FeetDry in forum FlashScan V2
    Last Post: September 23rd, 2008, 05:12 AM
