This is my first go round with a LBZ. Iv done the LB7 and LLY a few times and have had pretty good success with them both. I have eliminated the post injections on the LBZ by setting the max number of injection events per cycle to 3 in table B1021. That seems to be the only table i can find that has anything to do with deciding which injection events are going to occur. What actually tells the ECM what injection events to preform when. I assume that setting it to 3 will eliminate the 2 post injections. Will setting the table to 2 shut off the Pilot #1 or Pilot #2? The whole table is set to 3 injection events max but i know that at 5k RPM the injectors cannot preform 3 injections per cycle. somewhere something has to be setting when pilot 1 and 2 are and are not active.
What i want to do is raise the fuel pressure to 120 MPa or better in the cruising range and spray 2 very short pilots. Then advance the pilot 1 before main injection (somewhere around 40 BTDC) and space out #2 so its PW ends about 18-22 CAD before main injection occurs. I have discovered a slight MPG gain on the LLY by limiting the PI PW and spraying it about 20 degrees in front of the main injection. I think if i could split my PI into two even smaller events there may be gains to be had. Of course its going to be a little louder and my NOx emissions are not going to be the greatest.... minor details.
