Thread: Why are the stock value for B1978 different in E38 and E40
    May 2010
    Default Why are the stock value for B1978 different in E38 and E40
    I noticed the values for the B1978 are different between E38 and E40 stock files while they have the same knock sensors
    the value for all E38 ECMs are 120 Millivolts
    while the values for E40 are 400 Millivolts
    the description says that "Initial knock threshold voltage to define a real knock event"
    so if we could guaranty that 400 is correct for E38 that mean we can advance the timming more
    Any help will be appreciated
    EFILive Tuner
    May 2010
    Any body have any idea ?
    EFILive Tuner
    Default Maybe...
    E40: runs an LS2 (which is physically quite similar to LS1/6)...
    E38: runs an LS3 (which is physically different from LS1/6)...
    May 2010
    joe
    E38 also comes in LS2 for 2006-2007 C6
    EFILive Tuner
    Aug 2010
    If you use a value of 400 mV for the knock threshold (B1978) with an E38 / E67 ECM and LS2/3 knock sensors, you will not have any knock protection whatsoever.
    Recall basic electrical formula (Ohms Law, etc.) when considering this question. In this instance the simple V = I x R equation is helpful. The voltage of the closed system is a function of both amperage and resistance. Change the amperage, and you change the voltage. Change the resistance, and you change the voltage.
    A number of years back I spent a lot of R&D on getting an LS1-B PCM to correctly operate LS2 style knock sensors. It became evident that the hardware inside an LS1-B, E40, and E38 was quite different - controller to controller.
    My two cents is that the difference in B1978 values between the E40 and the E38 is a function of their own unique architecture.
    May 2010
    Thanks Taz
    So its not a sensor variation its a ECM variation
    I found some tunes from Diablo and SCT puts the values for E38 210 mv
    what do you think about this 75% difference than the stock value ?
    EFILive Tuner
  1. E40-E38-E67 B5101 Calc Error?
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 24th, 2011, 04:34 PM
  2. W427 HSV E40 or E38?
    By rally1 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 15th, 2008, 03:17 PM
  3. E38/E40 Pinout-Diagram
    By Black02SS in forum Gen IV V8 Specific
    Last Post: September 2nd, 2007, 08:30 AM
