Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Plx sm-afr v2 serial mods
    Mar 2012
    Default Plx sm-afr v2 serial mods
    Hi guys,
    I am trying to mod my plx and add a max3232 card so i can lod via serial on my v2. I have seen plenty of pics of old plx afr's modded but none that look like mine. Does anyone know where i need to solder on this card? Need the tx, 0v and v+
    Mar 2012
    Anyone?
    Mar 2012
    Update: Serial modification done and it works a treat. Compared serial to analogue and its bang on. Also compared the PLX to an Innovate and they are the same.
    Good job
    ( I couldn't find the thread here that showed how to add the serial comms mod, but it should be pretty straightforward )
    Now that I said that, it seems now (today) I'm easily bumping into that thread
    [ turns out I had already bookmarked in the "Collecting scattered links" thread and did not realize it ]
    PLX-SM-AFR-Serial-upgrade
    Mar 2012
    Cheers joecar.
    I think my PLX must be the latest generation maybe v3? Mine has a lot different pcb installed but either way I got it going. I used some info off that thread in regards to the TX and 0v .
    Jul 2003
    V3 has serial output and serial input....
    Very intriguing system..... I mainly like their new DM6... might make the jump if i can correctly hook it up to the V2.
    V3...?
    Jul 2003
    Yes plx v3
    Ah, PLX V3
  1. PLX SM-AFR Serial upgrade
    By ntae in forum FlashScan V2 BB Logging
    Last Post: May 25th, 2017, 08:26 AM
  2. setting B3618 PE AFR with cam and supporting mods
    By myws6formula in forum Gen III V8 Specific
    Last Post: June 17th, 2013, 12:47 PM
  3. plx sm-afr serial
    By blazinblue in forum General
    Last Post: June 23rd, 2009, 08:29 AM
  4. PLX SM-AFR Serial control not found.
    By aaronr in forum FlashScan V2 BB Logging
    Last Post: February 15th, 2009, 08:59 PM
  5. Anyone willing to convert my PLX to serial???
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 16th, 2008, 04:51 PM
