Results 11 to 20 of 29
Thread: New to EFI Live, help with updating 2000 to 2002 os
    Lifetime Member picnic_george's Avatar
    Jan 2007
    By the .tun he posted he's got a 2000 4wd 5.3 yukon and wants lean cruise, looks like he flashed an 02 12216125 DBW cal which isn't working properly(as expected).
    Dec 2013
    Quote Originally Posted by picnic_george View Post
    Exactly right, so what do I need to do in the tune to change to DBC? Is it as easy as changing parameters or do I need to swap segments?
    Jan 2007
    On my buddies car all the IAC values(and probably other values) were already inserted all we did was click the Y/N option IIRC for DBW and it worked just fine. This was a different PCM with some random azz cal we found online though so who knows what it was lol
    I do have a 2000 tahoe and I've been meaning to do the exact same thing since I have a lisenced pcm sitting in a drawer in my garage but I've been lazy lol
    You may find a 2002 tahoe/yukon cal that is already set up for DBC since Taz stated they came both ways. Friend has an 02 Yuk 5.3 and I'm pretty sure it's DBC I'll have to find out :shrug:
    But anyways I would definitely try turning off DBW and see what happens.
    Switch to OS 12212156 and pick a tune that has DBC. I dont know exactly which table/params make it easy to identify a DBC vs DBW tune offhand.
    Look at TuneFileDepot, there are tons of 12212156 files. Pick one from a Silverado, Tahoe, Suburban, or Yukon that uses a V8 and DBC.
    Jan 2007
    That yukon was a DBC, didn't do anything to the tune other than change the serial # on the vin. But here you go, hope this helps OS 12212156 .
    Dec 2013
    OMG Man! That is awesome. Worked the first time, no changes needed! Thanks a million. I got the lean cruise enabled now so Ill let you guys know what kind of mileage I get for work tomorrow.
    Summary for anyone reading along:
    for 512K LS1B when possible, choose a 12212156 file with matching throttle (DBC or DBW) and matching transmission (4L60E or 4L80E).
    Dec 2013
    Are there any indicators in the tune that we can easily identify whether it's a DBC or DBW and 4l60 or 80? That way we can reference this in the future.
  9. #19
    Jan 2007
    Quote Originally Posted by windydrew View Post
    No problem, good luck. Hope it turns out well, let us know
    If I was at my laptop to look I could tell you where. Under vin or permissions or whatever it will say what transmission. I can't remember where but it tells you what type of throttle it has, says f-bofy, y-body etc and shows tb(under system or something like that).
  10. #20
    In the transmission segment there is a table for the gear ratios:
    - 3.06, 1.63, 1.00, 0.70 -> indicates 4L60E,
    - 2.48, 1.48, 1.00, 0.75 -> indicates 4L80E.
    Shift pressure tables: if these have an immediate sharp jump up to max pressure, then it's probably a manual transmission,
    In the System segment look at G1206 and G1207 to see indication of DBW (what picnic_george said).
  1. Updating to 2002 tune from 2000
    By Bill00Form in forum Gen III V8 Specific
    Last Post: May 17th, 2012, 03:17 PM
  2. upgrade from 2000 o.s to 2002.os
    By smslyguy in forum Vortec V6/V8 Specific
    Last Post: August 31st, 2009, 06:18 AM
  3. Anyone done a Corvette 2000 OS to 2002 OS change?
    By aleco99 in forum Gen III V8 Specific
    Last Post: September 24th, 2007, 01:24 AM
  4. Does any body have a OS 2000 to 2002
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: August 21st, 2007, 08:40 AM
  5. Going from 2000 to 2002 OS problem ?
    Last Post: June 9th, 2007, 10:00 AM
Tags for this Thread
