That's what I thought too. But it's not referencing the right tables for the tunes selected. I have verified with the scan tool it's switching correctly but the tunes aren't running as commanded.
The dsp#2 has my turbo brake but it is still active on all the other tunes.
Also I'm getting a weird smoke and buck issue on the bigger tunes. If I run the same tune alone, non - dsp, they work great. Could the Egr cause that if it's not blocked even though it's turned off?
