Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 56
Thread: Tool to help tune A4 shift points...
  1. #31
    Dec 2010
    Have to agree! Used this tool for the first time and the visual is great!
  2. #32
    For reference:
    PT shift table relationships:
    basic relationships:
    1->2 curve should be above 2->1 curve;
    2->3 curve should be above 3->2 curve;
    3->4 curve should be above 4->3 curve;
    additional relationships:
    3->2 curve should be above 1->2 curve;
    4->3 curve should be above 2->3 curve;
    this can be summarized as: the curves cannot cross anywhere;
    if they cross anywhere, then you will not be able to predict what gear the TCM selects when the operating point hits the cross.
    This is what post #1 is saying.
  3. #33
    May 2015
    This old thread and the spreadsheet it contains has really help me to visualize my shift points, and I would like to thank SSpdDmon, joecar and the rest of you! I've been experimenting with the shift points and comparing to stock files and others. I've attached my current version, I'd be interested in any input.
  4. #34
    Quote Originally Posted by Illegal Vette View Post
    Thanks for sharing.
    I opened it in LibreOffice Calc and it looks good
  5. #35
    May 2015
    Thanks for sharing.
    Thanks for taking the time to look at it, I'm flying by the seat of my pants here and your opinion means a lot!
  6. #36
    Some comments on shift curves:
    - you can space out each shift curve and its corresponding upshift curves so that they have more vertical distance between them (see 2002 Camaro A4 tune file), this will improve drivability (i.e. engine rpm "feel" will better match "urgency" of throttle position; i.e. for these pairs 1->2 and 2->1, 2->3 and 3->2, 3->4 and 4->3; when editing, remember to maintain this relationship:
    - same with TCC apply/release curves, space them out (see 2002 Camaro A4 tune file), driveability will improve.
    Then when done editing, set all the WOT MPH shift parameters to the same values at the 100% columns in the PT shift curves.
  7. #37
    May 2015
    Thanks for telling me to match the WOT shifts to the 100% PT shifts. My WOT were a dash higher. It looks to me like my upshift and downshift curves are spaced out like you say, but my TCC apply and release are less so. Is this something I should be looking at?
  8. #38
    If it's a street car, then you can get muclecar feel if you unlock TCC at low VSS.
  9. #39
    May 2015
    Thus the 255's in the first 2 cells of 3rd apply and 4th apply on the A4 spreadsheet?
  10. #40
    I meant push the TCC release curve down further, for example look at 2002 Camaro A4 tune file, the 3rd TCC release and 4th TCC release are fairly flat down low... if your PCM keeps TCC applied on zero throttle, having the 3rd/4th TCC release curves low keeps the TCC applied until car is going too slow for TCC, but while above this it feels like a manual tranmission, and makes engine growl when you release throttle (i.e. musclecar feel).
  1. Little help with changing shift points
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: June 29th, 2009, 06:54 AM
  2. tuning shift points
    By hot-dog in forum Allison 5 & 6 Speed
    Last Post: February 28th, 2009, 08:03 PM
  3. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  4. Help with 80E shift points
    Last Post: May 20th, 2008, 03:08 PM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
