Results 31 to 34 of 34
Thread: help setup LC1 to V2
  1. #31
    Nov 2006
    LC-1 WBO2
  2. #32
    Mar 2014
    Thanks for that. Just because I like to be sure, this is what I'm after right?
  3. #33
    Yes, that's correct.
  4. #34
    Mar 2014
    I have an Innovate DB gauge, in the installation instructions, it says to tie the ground to the same ground source shared with the wideband controller.
    Presumably this doesn't need to be on the same bung, so long as it's the same ground?
    Also, I guess the 12V switched (for illumination) doesn't need to be the same 12V switched source as the controller (presumably better if it's separate?)
    For reference the Innovate install instructions are here.
    My apologies for the simple questions, here's another diagram just in case it helps someone in the future understand
  1. injector setup
    By odd boy in forum Gen IV V8 Specific
    Last Post: March 17th, 2011, 09:42 AM
  2. Calc VE Setup
    By DPS in forum Tutorials
    Last Post: April 18th, 2010, 10:48 AM
  3. setup info ??
    By 2004gmc in forum Lounge
    Last Post: May 12th, 2009, 12:31 PM
  4. RR Setup
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 12th, 2009, 03:25 AM
  5. LC1 setup for e85 ?
    By yellowC6ohio in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2008, 04:11 AM
