Results 1 to 10 of 14
Thread: Boost Tables info?? - EGR on/off
    Dec 2005
    Default Boost Tables info?? - EGR on/off
    I am tring to add boost to my tune and have a queston about adding it. If the EGR is disabled do I need to worry about adding boost to the EGR on tables too. My guess is no but wanted to ask before is just ASSume
    Senior Member Racehemi's Avatar
    Nov 2005
    You are correct, as long as the egr has been disabled, use the Desired Boost Levels with EGR Off (A), (B), or (C) depending on your baro.
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    Dec 2005
    great thx for the info.. any pointers on raising the boost? Do/don't? I am looking to get ~7-10lbs driving and max at 29-31lbs
    EFILive Reseller
    Nov 2005
    Just wanted to point out that in this case, disabled means "not commanded" or disabled in the program and not externally disabled.
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    lakingslayer
    Guest
    I just copy the modified table so both the EGR on and EGR off boost tables are the same. I have a blocker plate and electronic hardware to prevent the ECM from noticing the EGR isn't functional.
    Senior Member Wasted Income's Avatar
    Dec 2005
    Avoid raising the boost tables for idle speeds...the turbo will sound like it's trying to make boost at idle then. I just raised most of the table by 20% last night, and wow, what a difference.
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Dec 2005
    where did you move the boost from so I don't move the idle boost? Where in the tables.
    My guess
    Table B2206 Row 0-10 and don't change the boost on from 0-800 rpms?
    Dec 2005
    that's pretty much it. I didn't change anything at low fuel flow or at anything under 1000 rpm, but I raised the rest and then smoothed the transition. Seems to be pretty good thus far. I haven't played with EFI for a couple of weeks, and I wanted to play with something, so I moved the boost up a bit. Spend a little time playing with the boost tables, and you'll probably find something you like.
    Dec 2005
    I am trying to learn one section at a time and Boost it my starter thanks for the hints.
    Lifetime Member bobo's Avatar
    Nov 2005
    Boost is fun to play with. Just make sure the psi don't go over 30psi and don't build boost too soon...it robs you of power.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
  1. DURAMAX lly Boost tables
    By Banshee1973 in forum Duramax LLY
    Last Post: March 18th, 2010, 03:35 PM
  2. Boost fueling tables
    By limited cv8r in forum Custom Operating Systems
    Last Post: March 17th, 2009, 05:17 PM
  3. lbz boost tables
    By dynarex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2007, 02:54 PM
  4. ECT Boost tables inop
    By killerbee in forum Duramax LLY
    Last Post: February 17th, 2007, 01:24 PM
  5. Boost tables - mm3 per stroke?
    By turbo lcc in forum General (Diesel)
    Last Post: March 14th, 2006, 03:03 PM
