Where does EFI LIVE 7.5 expect to find this file on disk? It appears as if the file is not found or not being used.
I have used the RR endlessly without problem, but today I was trying to autotune my VE table with
RR. I was able to log both MAP and RPM, but my BEN variable, which I call CALC.WB_VE_ADJ is not showing up in the RR box and thus no changes are made to VE.
