Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 112
Thread: Help with vehicle staying running and cold starts without throttle aid...
  1. #71
    Aug 2013
    Okay. I pulled this file from holdencrazy... which is a repository for stock tunes. It's the same OS and calibration as yours. It should be a good tune file.
  2. #72
    Jan 2013
    Quote Originally Posted by statesman View Post
    When I go to copy this to my flashscan V2 it says it is not supported by bbx flashing etc.
    I don't have a laptop. How do I make this file usable, by the V2 handheld?
    Edit: Nevermind I think I got it. Opened it in Tune program and saved as a ctz file instead of tun.
    This should work correct?
  3. #73
    From V7 tunetool, open the .tun file and save it as .ctz.
    From V8 S&T, there's a tool to convert the .tun to .ctz.
  4. #74
    Jan 2013
    I did the Full flash with this file, then the cal flash with the most recent Mod9 file posted, then the TPS reset.
    And here is the log afterwards:
    LS1B_0553.efi
    Not the results we were looking for at all. In fact went in the opposite direction on drive-ability.
  5. #75
    Aug 2013
    Okay, I've looked at your log and it did fix the problem of your TC randomly adding air. Now we'll have a better chance of tuning out your surge. Do a log with the original pids you were logging... with the pids I listed in post #14... and log LTFT's instead of WB since you're in CL now.
    Also, read the tune back out of your PCM... save it as "GoodOS" and post it up with your next log.
  6. #76
    Jan 2013
    Ok here is the GoodOS file:
    Good_OS_Mod9.ctz
    I should be able to go back to the previous way of logging and get you some info later today.
  7. #77
    Jan 2013
    I opened my throttle blade a little more because it was still not wanting to start on dead cold starts sometimes, then logged RAFIG, applied that rafig then with that slightly modified tune I made this log:
    LS1B_0557.efi
    Rafig tune on TB set screw adjustment:
    Good_OS_Mod9_rafig.ctz
  8. #78
    Aug 2013
    Your cold starts are always going to be problematic until you widen the IAC air passage in that TB.
    Okay, here's Mod9.1. I called it 9.1 because it's only minor adjustments to Mod9. Small adjustments can do big things... sometimes.
    This is just a spark adjustment to help focus your idle to the target speed.
    Let me know how it goes.
  9. #79
    Lifetime Member 67SS509's Avatar
    Dec 2005
    Been following this and want to make a few comments based on my experiences.
    The size cam you are running should not be causing as much problem you are having. One thing I would do is cut the Base Spark back to about 19-20 degrees. Always include spark in your PID's. Your Idle Air numbers are just not big enough for a cam.....do you have a vacuum leak? Would explain all the surging. For better cranking add air in the Startup Friction Air table and then decay it faster. Crack your throttle screw to obtain near 0 IAC counts until you get the surging resolved and then set it to obtain 30-40 IAC counts under normal conditions.
    2002 Chevy truck, SCSB 2WD, Stroked LS3 w/Big Mutha Thumper cam
    2002SS Camaro LS7/427 with stock suspension setup
    2012 Chevy truck, SCSB 2WD, Magnaflow exhaust + K&N
  10. #80
    Jan 2013
    Here is a log from today of your mod9.1 tune, but the wife was in the vehicle so had the a/c running most of the time:
    LS1B_0563.efi
    At the last couple minutes of the log is without a/c running for sure though if it makes a difference
  1. Replies: 14
    Last Post: November 2nd, 2013, 06:17 AM
  2. LMM falls on its face on wide open starts/OK if I roll on the throttle
    By sledbuilder in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 3rd, 2010, 03:23 AM
  3. Car starts but won't stay running
    By brianjw4 in forum Gen III V8 Specific
    Last Post: April 10th, 2009, 10:37 AM
  4. Running way to lean in cold open loop. How do I fix it?
    By 1Hotbird in forum Gen III V8 Specific
    Last Post: December 24th, 2007, 04:50 AM
  5. Cold Start: Starts and stalls...
    By 808ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2007, 08:34 PM
