Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Segment swap causing different results than manual copy / paste
    Lifetime Member samh_08's Avatar
    Oct 2008
    Quote Originally Posted by darcy View Post
    Those tunes don't match OSs...how did you segment swap?
    Good call, going back through my emails I seen this: (me talking)
    "The 2004 SSR tune on tunefiledepot makes the throttle work correctly.
    Being that it is the same OS, I find it odd that it works.'"
    I at one point flashed the holden tune listed above and found it worked, but later tried the SSR and it also worked AND it was the same OS.
    Been a long time since I thought about a LS1 PCM's operation, but, isn't the TAC module required to be matched in some way to the pedal and PCM tune? In other words you can't take a truck pedal, Cadillac TAC and put a Holden PCM tune in.
    That was my thinking until I started flashing other tunes and getting different throttle operation with the same hardware...?
    Oct 2008
    When I was initially playing with different tunes to get the throttle working right, it was winter so I couldnt take it out and see a real world result. Here is what I found...
    Quote Originally Posted by samh_08 View Post
    So here is what I tried:
    Swapped all segments from my tune > holden = No good
    Swapped ONLY engine segment from my tune > holden = No good
    Swapped ONLY engine section MANUALLY from my tune > holden = Perfect!
    Swapped everything MANUALLY from my tune > holden = Perfect! --->> LOADED THIS TUNE
    When I open my tune, the engine size is wrong (says 5.3L when it was 6.0L)
    - The OS is the same
    - All of the segments have different ID's and checksums
    The car runs pretty good overall, except for cutting spark to 0* after a 1-2 shift AND keeping the timing at 0* until I left off.
    Engine size appears to be documentive only.
    Oct 2008
    Thanks Joe. It must not be derived from B0104 cause I changed that...?
    I've NEVER had the car drop timing like it did with this tune, so whatever is 'hidden' is definitely affecting the tune. Is there tools or anything I can use to view this data?
    Oct 2006
    If you can get the files in .bin format you can compare the raw hex values with Tunerpro.
    Once you have the definition built in Tunerpro you then make a .cax so you can edit with Efilive.
    The Tremor at AIR
    Oct 2008
    Just drove it again and posted a screenshot of what is going on. I can get it to repeat every time from doing the following: Rolling along in first, going WOT, shifting to 2nd. As soon as it hits second (maybe a tad sooner) it cuts the spark advance until I let off.
    In the attached shot, I hit the throttle letting it shift into second then let off enough to pick the spark back up.
Name:	cutting spark.png
  1. AutoVE copy and paste
    By amiller406 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 14th, 2012, 02:38 PM
  2. cant copy and paste with 7.5
    By articSS in forum Gen III V8 Specific
    Last Post: October 7th, 2008, 12:18 PM
  3. Copy and Paste
    By Lextech in forum Custom Operating Systems
    Last Post: January 2nd, 2007, 05:34 PM
  4. Do we have a copy and paste feature
    By Dirk Diggler in forum General
    Last Post: February 20th, 2005, 06:49 PM
