Originally Posted by
joecar
Hi Josh,
Are you using the serial comms connection (this is way better than the analog connection)...?
With the serial comms connection, do you have it wired as a null-modem cable (Tx and Rx swapped)...?
With the serial comms connection, which pids are you using...? (should be: EXT.WO2LAM1, EXT.WO2EQR1, EXT.WO2AFR1, EXT.WO2ST1)
If you can get serial comms to work (you should be able to), you can avoid the analog connection.
What is the version of the firmware in your V2...?
Which build version V7 software are you using...?
You still need V8 as this includes V2 firmware updates.
V7 software includes the scantool and tunetool.
V8 software includes the tool for configuring V2 for BBx (logging, reading, flashing), the explorer tool (uploads/downloads logs and tunes) and V2 firmware.
