Results 21 to 30 of 33
Thread: COS 3 not responding to VE map changes
  1. #21
    Jun 2013
    I'm not getting "sane" numbers on my BEN correction maps. 5,000 rpm and 100kpa might read .011 or something close and the lower the rpm/kpa the closer the values are to my actual ve table. This started as soon as I went to speed density.
  2. #22
    Jun 2013
    Maybe I should just give up on these SD80s and get some ID1000s...
  3. #23
    Oct 2006
    Post a screenshot of what you are seeing.
    The Tremor at AIR
  4. #24
    +1 screenshots... and tune/log files.
  5. #25
    Oct 2006
    You may have to play around with A0014 and A0008 to achieve the desired results, seems I had the same problem with a stock setup and that is how I resolved it.
    2006 Trailblazer
  6. #26
    Jun 2013
    Here is a screenshot of the insane values that I'm getting and check out the ve table that's actually working for my car. To me the ve table looks terrible but this is what gets the car to run well. I'm still unsure of the injector characterization values I'm using but it's like pulling teeth finding proper values. Once again thanks to everyone for helping me with this. I know you are all busy people and you by no means owe me anything.
    Attachment 16987LR4 COS3 SD_0006.ctz
  7. #27
    Screenshot attachment link is broken...
  8. #28
    Jun 2013
Name:	insane values.JPG
  9. #29
    Feb 2012
    VE does look pretty ordinary, but it'll never run nice with B3647 the way it is - apart from 2 cells, it hasn't been fixed up since you converted to a COS.
    You've mentioned the AFRs you're getting, but you need to look at what it is you are commanding.
    BEN numbers certainly look wrong, but it's difficult to offer any further analysis or insight without a log. Can you past the log that made that map?
  10. #30
    Aug 2013
    Is your IAT sensor integrated into your MAF sensor?
  1. Controller not responding
    By 08pearlZ06 in forum FlashScan V2
    Last Post: February 17th, 2014, 08:43 PM
  2. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  3. COS 1 won't run duel spark map?
    By 4wheelin in forum Gen III V8 Specific
    Last Post: November 21st, 2008, 01:46 AM
  4. COS#3 ... Max MAP = 105kpa in the scanner?
    By turboberserker in forum Custom Operating Systems
    Last Post: February 5th, 2006, 08:13 AM
