Results 1 to 7 of 7
Thread: 2.2 s10
    Feb 2014
    Default 2.2 s10
    Tring to find a way to get some real tables into a blown 2.2 the ve tables suck ,actually everything sucks, i can repin if this can be done , needs to be atleast one bar ve and im not sure if this can be done any help would be appreciated
    Thanks as always
    jim
    Feb 2014
    will efi live build a custom operating system for payment ? I have a really good reason to get the 2.2 s10 with a 2 bar map and some timing tables
    thanks
    jim
    No, this PCM would be near on impossible to work with for a custom OS.
    May 2010
    Quote Originally Posted by SW1911 View Post
    thanks
    jim
    There are get around ways to tune the alpha n setup in this pcm and works reasonably well. Is it correct? absolutely not. I am still daily driving my 98 S10 2.2 that has been turbocharged for the last 6+ years with 15-20 psi and maintaining the correct afr under boost and normal driving conditions. So have quite of few other people across the internet. Get the 2 bar map thinking out of your head when working with this pcm.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
    Feb 2014
    thanks guys
    Feb 2014
    Quote Originally Posted by slows10 View Post
    you have peaked my interest with "the incorrect way " is this something you would be willing to share just for comparison ?
    thanks
    jim
    May 2014
    With what you are doing or thinking- how much more work is swapping in a friendlier ecu?
  1. LS1 in an S10... need help
    By rb1 in forum Gen III V8 Specific
    Last Post: July 7th, 2013, 12:24 AM
  2. 99 S10 2.2 questions
    By gotabav in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: December 9th, 2011, 12:58 AM
  3. cam upgrade..98 s10
    By 98super10 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: June 13th, 2011, 02:34 PM
  4. '03 Express van 6.0L in '00 S10
    By Sherk in forum Gen III V8 Specific
    Last Post: June 5th, 2008, 06:46 PM
  5. 99 S10 with 4 banger
    Last Post: June 5th, 2006, 02:18 PM
