Results 11 to 20 of 27
Thread: What do I do with the text file I received from my tuner?
    Jun 2014
    1. Start one thread, not 4.....
    2. Call your tuner and ask him what the go is. Have you opened it to see what is in there?
    The 2Kb log file sounds like it only wrote the header info, as if you hit the cancel button accidentally after starting the log. Was there any data displaying on the screen while the log was being recorded? The only other option I can think of is that the Autocal/V2 may need to have the firmware updated, which may be what the text file is about.
    1. my apologies for the multiple threads. I posted them in different forums in hopes to get a reply.
    2. I did another log moments ago...now nothing is recording. Something is definitely not right. The timer is rolling. But when I unplug the Autocal from the car and plug it into my laptop and open up EFI Live Explorer to get the file, nothing is there. I do not take my laptop along to do data logs so I cannot verify what, if anything was happening there.
    3. All updates (hardware/software/firmware) are current.
    4. It is Sunday, my tuner is not available. I thought I would try for answers here.
    ~Troy~
    Did you ask your tuner about this..?
    I merged all the threads into this one, so the above replies may appear to be out-of-order wrt the merged threads.
    Lifetime Member limited cv8r's Avatar
    May 2005
    if you can post up the file, maybe someone can help you better.
    It's all good until it goes "Bang"
    Feb 2012
    Is it the options.txt file?
    If so; this is to programme the Autocal with the appropriate pids - your tuner should have given some instructions with it...
    swingtan
    Guest
    Just confirming, are you stopping the log before disconnecting? If you don't, then the log file can get truncated.
    Jun 2014
    This is the file... AutoCal E40 scan settings.txt
    Yes, I stopped the log after I parked the car. Granted, the timer still runs, but the log is "paused".
    I still haven't heard back from my tuner yet...
    Can you post the file "AutoCal E40 scan settings.txt" here...?
    Sounds like what darcy said above, you have to program this into your V2 (using V8 S&T).
  9. #19
    Jun 2014
    Here is the actual file..
  10. #20
    Senior Member KhakiCummins's Avatar
    Sep 2011
    Quote Originally Posted by twilt View Post
    Are you STOPPING or PAUSING the log? They are not the same thing.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  1. Error $0281....no data received
    By y2k2z28 in forum FlashScan V2 BB Logging
    Last Post: October 23rd, 2016, 11:08 AM
  2. Need a little help with the calc_pids text file
    By smslyguy in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:12 AM
  3. Just received a used RR and EFIlive flashscan v1.2.. HELP!
    By 99ss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 25th, 2007, 09:32 AM
  4. I have received a little bit of bad news.
    By esco35m in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2007, 07:16 PM
