Results 1 to 4 of 4
Thread: Understanding GM Torque Based ECU's
    Default Understanding GM Torque Based ECU's
    So I was doing some searching to try and improve upon my existing knowledge on how these later model ecu's work and found a page on 1 of GM's Patent's which explains how they do there idle control etc and thought it might be worth starting a thread on helpful information for this line of ecu's.
    Control system and method for idle speed control torque reserve reduction
    The main reason I have found this interesting is because I've been logging my e83 ecu and have noticed since day 1 on the stock tune the car kept running negative timing at idle once the car was fully warmed up and from past experience on the other ecu's (e38,ls1) this generally means it has too much air entering the motor and it's last resort to getting the idle down was to remove timing.
    A side of affect of it doing this, is the fuel trims at idle are showing excessively lean and the ltft & stft starts going positive in a big way, I even went as far as modifying the VVE & Maf scale with no difference, so this left me with the assumption that with negative timing occurring unburnt fuel is getting blown straight out of the exhaust.
    Not good for the fuel miser.
    Unfortunately I don't have the relevant tables I need to try this out with in the program, but I can at least test it out and report back if the tables available in another application do.
    swingtan
    Guest
    Nice find Dave, I'll need a bit of time to read through that but I have also seen the very low timing in the E39 SIDI. I was able to bring it up a bit by playing with the torque response tables at idle. I may have fudged the torque model as well, I can't remember now....
    Very interesting Dave, thanks.
    Another long but good read:
    http://www.google.com/patents/US20110139117
  1. E83B ECU Torque Limits
    By Tre-Cool in forum E78, E83, E84 PFI ECM's
    Last Post: June 5th, 2014, 02:58 PM
  2. Torque based Fuel Maxes out at 886
    By Kirker912 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 4th, 2013, 06:31 PM
  3. torque based fuel transient
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2010, 03:53 PM
  4. 0202005 is based on what OS?
    By Highlander in forum Custom Operating Systems
    Last Post: August 22nd, 2009, 09:37 AM
  5. Torque Based Fuel Tables LBZ
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 2nd, 2009, 11:22 AM
