Results 11 to 20 of 26
Thread: Aem failsafe gauge not serial
    Aug 2007
    And this...
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    *UNITS
    #Code System Abbr Description
    None None "" "No units"
    # Add slot definitions here
    00 GMC,LQ4, Jarrett Faggart pistons, callies rods, Ebay studs, LS9 gaskets, 317's, KBRacing KIT, PT76/75, treadstone intercooler,Eboost2, dual walbro, FIC 75lb, br7ef, Trutrac, Shaftmasters Shaft, 3.5" DP w/4" magnaflow dumped, turbo blanket, Circle D 3200, Jake's built 4l80w/brake, hydroboost, EFILive v2,Lunati dual springs,222/226 cam, cal-tracs, QA1 front shocks, Street/strip Bogarts,Drum swap, Alky-control,MSD8733 936 HP to the tire DD.
    Aug 2007
    Stubbling around I found this ...is that what I need? My level of ignorance here shameful . thanks for assisting.
    -- WO2A.AFR_WBC1
    return pid("AD1")*1.6+9
    Aug 2007
    I tried to change those properties in v8 and could not get them to show up once I selected that pid when I checked the pid properties. Still looking for help please.
    Copy the attached calc_pids.txt file to this folder: My Documents\EFILive\V7.5\User Configuration
    and then start the scantool and select the pids CALC.WIDEBAND and CALC.WO2BEN.
    Edit: file deleted because it was corrupted (CRLF got munged).
    Aug 2007
    It says invalid attachment when I try to open or copy. Could you email to rodneyhorne1@gmail.com ? THANKS for helping!
    tried again, got it loaded, will report back. THANKS
    Aug 2007
    open scan tool and got this error...
    Error code: ERR_CONFIG/92
    C:\Users\st0114\Documents\EFILive\V7.5\User Configuration\calc_pids.txt(81): Slot CLC-00-100 with units “LAM not found. .
    oh, hold on a sec...
    Aug 2007
    ok thanks
  9. #19
    Aug 2007
    Joe, is it something I could have done wrong. I copied the entire text in place of the other text in the Calc_pids under the My Documents\EFILive\V7.5\User Configuration. Looked correct because the first part of what you sent was exact to the first part of what was there so I replaced the entire text with what you sent. I am just being overly cautious telling you this. Don't want you to be running down my mistake. THANKS for your help as always!
    PS I cannot open tune or scan with this error code.
  10. #20
    The calc_pids.txt file that Joe posted has been somehow corrupted. I've fixed it and attached it to this post as a zip file.
    After unzipping the calc_pids.zip file so that the calc_pids.txt file ends up in the \My Documents\EFILive\V7.5\USer Configuration folder, re-start the V7.5 Scan Tool software and make the following PID selections:
  1. AEM Wideband Serial Hook-up -
    By RamAir in forum Petrol / Gas
    Last Post: May 29th, 2013, 11:03 AM
  2. 06 LLY Fuel Gauge - empty gauge with 7 gallons left
    By timvan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 5th, 2009, 02:35 PM
  3. Problems with AEM Uego serial logging....
    By BlackGMC in forum FlashScan V2 BB Logging
    Last Post: July 19th, 2008, 04:53 PM
  4. AEM Gauge type 6 in 1 WB UEGO controller
    By JET LEE in forum Gen III V8 Specific
    Last Post: January 25th, 2007, 09:25 AM
  5. Anyone using AEM WB?
    By 12sec.5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 04:02 PM
Tags for this Thread
