Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: NGK AFX Stoich Value
    Mar 2014
    Hello and thanks for help.
    yes I read and tried that text file but I think the voltage offset of ad1 is throwing it out. 0.5 to 4.5
    I will retry the xls input again, I dont know how to calibrate the ad inputs though.
    regards gav
    Quote Originally Posted by Gav View Post
    regards gav
    You measured with a DMM and see how much voltage offset...?
    Mar 2014
    Hi Joe,
    Sorry what i meant is that from the Manuel :
    'Vout is the analog voltage of the AFRM(0.5v to 4.5v)' So it must output 0.5v at 9 AFR and 4.5 at 20 AFR. By the way it is the 2nd version i think of the NGK AFX.
    Also from the book:
    Gasoline AFR = {(Vout-0.5)x2.75}+9
    Lambda = {(Vout-0.5v)x0.189)}+0.62
    Gav
    Hi Joe,
    Also from the book:
    Gav
    Post the user manual you have.
    Is it the same as this one (see page 11): afx_tuning_manual_rev_06.pdf
    Feb 2012
    Sounds like its a NTK AFRX, Joe.
    Gav, have a look at this thread: https://forum.efilive.com/showthread...-Ratio-Monitor
    Mar 2014
    Hi,
    yes it is the one darcy posted. In that thread shows the user manual and shows designed to run on 14.7 as stoich. I thought I was losing it as most other people were getting it to work with a different formula....might have to alter the text file for afr and ben then?
    thanks for help this far though, regards gav
    Ah, it's an NTK and not an NGK... (the equation is different).
  1. NGK AFX with V2
    By Gav in forum External A/D inputs
    Last Post: December 16th, 2016, 09:20 AM
  2. Logging issues with NGK AFX
    By Always2Slow in forum FlashScan V2
    Last Post: January 20th, 2013, 03:35 PM
  3. Ngk wideband
    By DYNOBOB in forum General
    Last Post: December 12th, 2012, 01:31 PM
  4. Is NGK AFX compatible with V2?
    By Tackmaster in forum General
    Last Post: December 12th, 2010, 10:18 AM
  5. Wiring NGK Powerdex AFX to the V1 scan tool
    By voda1 in forum FlashScan V1
    Last Post: June 24th, 2010, 06:41 AM
