Results 1 to 10 of 15
Thread: What would stop car from providing spark during cranking?
    Jul 2003
    Default What would stop car from providing spark during cranking?
    I'm having a crank, no start condition with my car. More detailed info here: http://ls1tech.com/forums/general-ma...heck-next.html
    What signals need to be sent to the IGN relay under the hood to allow the injectors to fire and provide spark?
    Other than VATS and crankshaft position sensor, anything else that would prevent car from starting?
    What year/model/vehicle...?
    Do you have battery voltage at each injector and each ignition coil...?
    When cranking, do you see PCM signal at each injector and each ignition coil...?
    Jul 2003
    It's a 99 trans am.
    This is the first time I've had to troubeleshoot electical / wiring issues. Where exactly do I test the injectors and coil? I have confirmed there is no signal during cranking using a noid light. I've placed a multimeter lead down the boot beside both wires going into the injector plug, but am only seeing a negative value on the multimeter.
    Oct 2006
    Both injectors & coils use a common power input for each bank. If you do not have power at either with the ign on, start with the fuses & work from there.
    The Tremor at AIR
    Jul 2003
    Quote Originally Posted by 5.7ute View Post
    #1
    10-10-2014 01:06 PM by XtreemeChaos
    Looking for a little help here.
    http://www.hotrodlane.cc/New%20LS%20...0Not%20Run.htm
    Things I've checked per the above guide.
    Step 2: No DTCs after letting it crank for 15 seconds.
    Step 3: Fuel is enabled per EFILive
    Step 4: RPMs show ~150 while cranking in EFILive
    Step 5: INJR1, INJR2, ENG CTRL, ENG SEN, and A/C CRUISE fuses do not have power on either side.
    Step 5 links to the Ignition Relay diagnosis, which I can't find anywhere else.
    Other steps taken/notes:
    Ignition Relay replaced in the fuse box under the hood.
    Fuel pressure is good.
    Confirmed no spark by grounding spark plug.
    No Injector pulse - tested with noid light.
    Security light goes off after key is in ignition and turned on 4-5 seconds.
    Re-seated PCM harnesses.
    EFILive shows readings for Injector Duty Cycle, Spark, and Commanded A/F ratio.
    Jul 2003
    Checked the INJR1, INJR2, ENG CTRL, ENG SEN, and A/C CRUISE fuses and they do not have power on either side. I've also swapped and replaced the IGN relay.
    Quote Originally Posted by XtreemeChaos View Post
    It's a 99 trans am.
    I assume you set your DMM to VDC...
    if you don't see the signal from the PCM on any injector and coil, then either there are connector problems in the wiring, or there are ground problems.
    Let's see if I can dig up the 1999 F-car No-Start diagnostic chart.
    Jul 2003
    Is this the cart you are referencing? http://www.hotrodlane.cc/New%20LS%20...0Not%20Run.htm
    I followed it down to Step 5, which links to the Ignition Relay Diagnostic, but the link is dead and I can't find any other references to a Ignition Relay Diagnostic.
    Jul 2003
    Is this the chart you're referencing? I've made it down to step 5, where it links to an Ignition Relay Diagnostic, but the link is dead and I can't find any other reference to this diagnostic.
    In the attached zip, locate the diagram showing the ignition relay, and check that the relay has voltage, and that it gets signal... also check that the relay socket terminals are making good contact (not loose).
  1. Spark drops to zero after cranking
    By ferocity02 in forum Gen III V8 Specific
    Last Post: June 8th, 2014, 07:41 AM
  2. e38 NO SPARK, NO FUEL PULSE WHEN CRANKING...please help!
    By Nkemp in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2012, 06:34 PM
  3. Cranking fuel?
    By 94SS in forum Gen III V8 Specific
    Last Post: November 30th, 2010, 07:29 PM
  4. Car wants to stall with under heavy braking/fast stop!
    Last Post: April 16th, 2008, 07:45 AM
  5. Car is in OL. Stall after I stop car and restart
    Last Post: May 5th, 2007, 09:50 AM
