Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: 01-07 "4x4 Option" cax
    Aug 2006
    Default 01-07 "4x4 Option" cax
    I found an old .cax file for the 4x4 Options. It was created by CC + M. I am assuming M is Mick. I don't know who CC is. Anyway---I take NO credit for
    this. All I did was update it a bit and add this parameter for other years of LS1b PCM Operating Systems.
    These "4x4 Options" .cax files are for the 2001-2007 LS1b PCMs. After these are installed you will find the parameter B9103. These .cax files allow
    you to set the "4x4 Options" to 2wd or 4wd. This may come in handy for retrofit projects. I'm sure I don't have all of the operating systems covered
    for those years but there are a total of 19 operating systems covered in these 7 .cax files. I didn't make any for the 1999 and 2000. I feel it is too
    easy to upgrade those to the better 2002 operating system. Follow the directions in GMPX's sticky about .cax files for where to install them into the
    software. Remember, If you already have .cax files that cover these O/S, you will have to add the contents of these into those folders. If you don't
    already have any .cax files for these O/S, you will have to make duplicate copies of them and name them the number of the O/S that they correspond to.
    zip file updated on 10-20-14
    Jeff
    Last edited by Lextech; October 20th, 2014 at 02:02 PM. Reason: Correct a mistake.
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    May 2012
    Is there any 4x4 cax file for this OS?? 12587604
    Aug 2006
    Yes, Look in the zip file that was posted.
    Jeff
    May 2012
    Quote Originally Posted by Lextech View Post
    Jeff
    Thank you a lot
    Used the 04 Cax file and renamed it with 12587604.cax and saved this file on calibration. opened my tune file and it shows the options is this ok?
Name:	CAX FILE INSTALED.png
    Aug 2006
    Quote Originally Posted by 400ss View Post
    Thank you a lot
    Hhmmm, I think you found an error on my part. Open that 12587604.cax and change the address to 196E4.
    I will update the zip file if I can figure out how.
    Jeff
    May 2012
    i did it and reestarted with the unmodified tune and now it shows 2WD, that was the error?? that it didnt whow that on the other address??
    Nov 2005
    Why not just start with the correct base file? (2wd or 4wd)
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Aug 2006
    I completely agree with that. That is what I prefer whenever possible.
    PS: I am in the process of trying to get the zip deleted so that the correct info can be posted.
    Jeff
    Aug 2010
    Thank you a lot
    400ss ... when using a *.cax file (whether written by you personally, or someone else) one of the main quality assurance checks is your own brain.
    When you opened the "B9103" parameter for the first time, if written correctly, it should have displayed "2wd". In the screen-shot you posted it displayed "<4>".
    This should have immediately indicated to you that something was wrong / incorrect.
    You got lucky this time. The parameter at 196B4 is the Reverse Lockout Speed (reverse inhibit with a manual transmission). It would have originally had a value of 1024 ($0400) which corresponds to a speed of 8 MPH. By applying the "2wd" button in B9103, you simply set this parameter to 0 MPH.
    The new address supplied by Lextech (196E4) appears correct - although I have never tested this proposed change to a GTO OS in a running vehicle.
    Regards,
    Taz
    Aug 2006
    The zip file in post #1 has been updated on 10-20-14
    Jeff
  1. 01-07 "Gear Indicator Type" cax
    By Lextech in forum CAX Files
    Last Post: December 20th, 2016, 10:58 AM
  2. "File Sys FULL!" followed by "ERROR: $0520"
    By Sushisan in forum AutoCal
    Last Post: April 24th, 2012, 06:35 AM
  3. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
