Was Cruising through things and noticed that there was a patch for the RSA Security for the CM2200A. Got one sitting here(2011), haven't even tried hooking it up to the V2 yet, but whats the process for reading out the truck? Can we read out the stock file like normal? and then apply the RSA bootloader patch, then flash over the stock/modified tunes that we read off the truck? or do we need to find some other method (like the LML or getting a dealer reflash) for acquiring another stock file that can be flashed in after the RSA patch?
If I can get a read out without the rsa patch, then ill run outside and grab a read off the truck and mail it in, seeing that there isn't calibration support as of yet. Just curious. Haven't really dug into it yet as Ive been busy with the LMLs.
