Results 11 to 20 of 31
Thread: Flashing MIL after 24x conversion
    Quote Originally Posted by bubba68ss View Post
    Also gm.tstate00 pid says 'no' for in p/n while monitoring. is the pcm seeing this and not letting CASE work?
    Maybe...
    you might need to swap the trans segment from a manual trans file with same OS id (there may or may not be one available).
    Aug 2012
    My summary page states that trans type is 'manual'. Why would it looking at auto trans range selection?
    Post a screenshot of this...
    if it's derived from the VIN then it is meaningless in regards to what the calibration actually contains.
    Aug 2012
    I posted my tune on the first page. Post two I think. When I open tune it states 5.3L as engine and Manual as Transmissionn type.
    Aug 2012
    This is my problem. I have 32 and 34 grounded and PCM still thinks I am in Drive. P/N status is 'NO'
    What do I do?
    Aug 2012
    Can you move this thread to the appropriate category so I can get some more views? I didn't realize I posted it in the Scanning forum.
    Aug 2006
    Do a segment swap from an auto trans vehicle. Then ground C1-32 and C1-34 during the relearn procedure and see if that works. If it does then you can flash your manual trans segment back in.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Moved thread to Conversions.
  9. #19
    Aug 2012
    Worked great, Lextech. I am now able to do crank relearns.
    Unfortunately I am still getting a large amount of misfiring on cylinder 4 and 7 after this conversion. New ckp, swapped coils with 4 and 8, new wires... ran great before the swap.
  10. #20
    Aug 2006
    Unfortunately I am still getting a large amount of misfiring on cylinders 4 and 7 after this conversion.
    You are using a Gen3 calibration on a traditional smallblock Chevy engine. They don't have the same firing order. Check the wiring portion for the firing order of the coils and injectors.
    Jeff
  1. Efi 24x Conversion Startup Issues
    By jahajazz in forum Gen III V8 Specific
    Last Post: December 16th, 2012, 05:20 AM
  2. Replies: 25
    Last Post: May 28th, 2010, 01:12 PM
  3. 24x conversion questions
    By monzaaddict in forum Conversions / Aftermarket Parts
    Last Post: July 5th, 2009, 12:11 PM
  4. flashing MIL?
    By Thimble in forum General (Petrol, Gas, Ethanol)
    Last Post: May 7th, 2007, 01:44 PM
  5. MIL for a LS1 conversion
    By Biggsy in forum Gen III V8 Specific
    Last Post: April 7th, 2007, 05:44 PM
