Page 1 of 7 123 ... LastLast
Results 1 to 10 of 69
Thread: New member looking for some input on tune
    Nov 2014
    Default New member looking for some input on tune
    Hi guys,
    So I have been studying and reading thru here (Reading the trans tutorial, reviewing older posts) and I was wondering if I could get your guys opinion on this tune and will be a safe bet to start with on the 04 GMC Denali out in the garage. Just looking to firm up the shifts for starters and wanted to get opinions before flashing it as I dont want to hurt anything.
    I removed 50 percent of the tm and upped the pressure 10% and shortened the shift times to .250........ Right now without this tune the shift is very lazy. Has a fresh trans in it and I would like it to last!
    I wanted to work on this first then start tweaking the engine settings.
    Thanks for any input guys!
    Denali Modified shift.tun
    So the vehicle is otherwise stock (mechanically)...?
    Nov 2014
    Yes it is stock right now.
    Nov 2014
    Would I be better to do something else instead since it is stock?
    Just looking to have firm positive shifts nothing gear banging. Was also planning on installing the corvette servo also for a little bit more.
    Thought I would start here before changing anything.
    I'm still looking at it.
    Nov 2014
    No problem, thank you for taking a look!
    Just trying to learn.
    Nov 2014
    Just wanted to check in and see if anyone had a chance to take a look and if what I am doing is going in the right direction.
    I'm slowly taking a look (I got family in the hospital so we've been spending most of our time there)...
    I'll take a closer look today (sorry it's taking so long).
    Nov 2014
    I'm sorry to hear that! I hope they will be doing better! Family is the most important thing!
    I'm making various edits to your tune file (shift, pressure, shift time, PE Enable...)...
    you will need to install the latest software (to open .ctz files): Update-Oct-28-2014
    I'm editing your WOT shift points because they are upside-down...
  1. Help give input to my tune/scans- OL AutoVE/AutoMAF
    By ddnspider in forum Gen III V8 Specific
    Last Post: August 7th, 2013, 11:04 AM
  2. Looking for tune input
    By devlmaycry in forum Gen III V8 Specific
    Last Post: January 29th, 2012, 10:04 AM
  3. new member
    By Baldric in forum Tuning For Economy
    Last Post: May 4th, 2009, 03:18 AM
  4. ** New Member **
    By Nemo in forum Lounge
    Last Post: November 16th, 2008, 08:59 PM
  5. New member, need some help to get going....
    By doorunrun in forum EFILive V4
    Last Post: February 11th, 2008, 02:40 PM
