Results 1 to 5 of 5
Thread: tuning larger injectors for boost.
    Jul 2013
    Default tuning larger injectors for boost.
    Hello, I am trying to get all my ducks in a row before starting my tuning. I am building an 04 4.8 silverado 5spd with a custom built forward mount turbo system, I have a set of trick flow 55# injectors (http://www.trickflow.com/partdetail....5&autoview=sku) and was wondering if someone could give me a run down of where and what needs to be done to tune these in. I am also wondering if the maf will be able to handle/accurately read 12psi of boost or should it just be eliminated? thanks. Eldon.
    Nov 2014
    good question. im interested in answers as well.
    Those injectors are rated to flow 55 lb/hr (6.93 g/s) @ 43.5 psi.
    Your rail pressure (to be measured with reference hose removed) would be 58 psi;
    scale IFR for 58 psi as follows: 6.93 * sqrt(58.0/43.5) = 8.00 g/s
    If FPR is manifold-referenced, then B4001 IFR table is 8.00 g/s all across;
    If FPR is un-referenced, then B4001 IFR table starts at 8.00 g/s in the zero VAC cell, and slopes up according to 8.00 * sqrt((400+VAC)/400) (or use the spreadsheet).
    THEN:
    you have to populate as many of the other injector tables/parameters from the injector specs.
    ALSO:
    You then edit B3701 VoltagexMAP correction to make it flat all across or sloped.
    Eldon, sorry I didn't see your post back in 2013.
    Jan 2014
    informative though.
  1. 7.4 Larger injectors, which ones..
    By Stamm1 in forum Vortec V6/V8 Specific
    Last Post: January 14th, 2017, 03:55 AM
  2. How to compensate for larger injectors?
    By Zorganov in forum Duramax LB7
    Last Post: November 9th, 2016, 11:36 AM
  3. Tuning for Larger Injectors
    By LastCall in forum Gen III V8 Specific
    Last Post: November 22nd, 2011, 04:33 AM
  4. larger high impedance injectors
    By 496chevy in forum Custom Operating Systems
    Last Post: February 7th, 2009, 08:02 PM
  5. How To Tune For Larger Injectors
    By RacerChris in forum General (Petrol, Gas, Ethanol)
    Last Post: November 9th, 2005, 02:20 PM
