Results 1 to 7 of 7
Thread: Wideband Analog Connection Trouble
    Oct 2011
    Default Wideband Analog Connection Trouble
    Hello everyone,
    I'm currently trying to connect my wideband sensor to my V2 flashscan but I keep getting the following error regardless of any changes that I make to the calcpids.
    Any help will be greatly appreciated. Thank you in advance.
    Error code: ERR_CONFIG/92
    C:\Users\Francisco\Documents\EFILive\V7.5\User Configuration\calc_pids.txt(45): Slot F001 not found. .
    Using Windows Explorer, can you locate the actual folder pathname that calc_pids.txt is located in...?
    Then, in the V7 scantool, go Edit->Properties->Folders and see if the User Configuration folder pathname matches the actual folder pathname you found with WE.
    Also:
    Your calc_pids.txt is not correct...
    this:
    Code:
    *CLC-00-001     10.00          20.0        .1   "{EXT.AD2}*2+10"
    should be like this:
    Code:
    *CLC-00-001
    AFR     10.00          20.0        .1   "{EXT.AD2}*2+10"
    Are you sure there is not an already made calc pid for your wideband...?
    Also, the precision would be better at .2 or .3 rather than .1.
    Oct 2011
    Thanks for the reply joecar.
    I checked the pathname both in windows explorer and v7 scantool and they do match. Also I'm using Daytona sensors Wego IV wideband system and I didn't find an existing calcpid for this unit.
    Also, there should be at least 2 blank lines at the end of your calc_pids.txt file.
    Did you edit CLC-00-001 as shown in post #3 above...?
  1. Analog wideband help for new starters
    By braapp in forum External A/D inputs
    Last Post: March 14th, 2014, 07:02 AM
  2. Error $5 (analog wideband logging)
    By rumblebox in forum FlashScan V2
    Last Post: August 22nd, 2013, 05:07 AM
  3. Analog wideband install?????
    By T&A Custom Rides in forum General
    Last Post: January 30th, 2012, 08:52 PM
  4. Autronic MAFM1 wideband analog to V2
    By APS Luis in forum External A/D inputs
    Last Post: July 10th, 2011, 02:30 PM
  5. Lost all wideband analog and serial pids
    By Wichita Dyno in forum General
    Last Post: August 23rd, 2010, 04:24 AM
