So the BBx for P12 didn't make it in? Trailblazer is acting funny and wanted to "read" (Tune section, not Scan) the PCM with V2 controller no-can-do has P10 and P11 but no P12, WHY?
2006 Trailblazer
P12 has been in the V8 BBx software for a long time.
To add support for P12 to BBx, do this:
Right click in the blue section (of the [F5: BBX]->[F2: Scan] window) and select "Add", then right click the engine controller area and select P12.
Sorry, you said "Tune not Scan", I read that as "Scan not Tune".
I'll try again...
To add support for P12 to BBx (for reading and flashing), do this:
Right click in the blue section (of the [F5: BBX]->[F3: Tune] window) and select "Add", then right click the engine controller area and select P12.
Got it, thanks!
You tha man!
2006 Trailblazer
Well not getting there, seems I get a code about midway through read, $0281 No data received. The controller does the orange>blue LED flashes, then about midway through it stops instrument lights flash on and off, controller then flashes orange a few time then the error code displays.
P12 Config Files are present in EFILive Explorer, Explorer shows that there was an attempt to create a P12 (P12_0013) file in Read section, size is 1KB.
Never Mind!
Formatted the Config File and did the FlashScan P12 addition and programmed the controller again worked.
2006 Trailblazer
After you get that error (and before powering off FlashScan), select the option to save a trace file: [F1 Scan Tool]->[F3 Scan Options]->[F1 Save Trace File].
Then use EFILive Explorer to copy the saved trace fiel to your PC and email it to me at [email protected],or attach it to this thread.
