Results 1 to 10 of 10
Thread: HELP WITH V2/T43. Won't read license after updating firmware?
    Sep 2012
    Default HELP WITH V2/T43. Won't read license after updating firmware?
    I need help. I updated my firmware, bootloader, etc. on the V2 last night and all of the EFILive software. After the updates, it will flash the ECM, but not the TCM. It says it cannot verify the license. I have flashed this vehicle hundreds of times prior to this. Any help is appreciated.
    What are you using to flash (V7, V8, V2/BBx)...?
    Send a license backup file (*.lbu) from your FlashScan device and a trace file (*.htx) of the failed flash attempt to support@efilive.com
    Instructions on how to get those files here:
    https://support.efilive.com/kb_artic...9413-RPHL-6309
    https://support.efilive.com/kb_artic...8552-EOAJ-5912
    Junior Member Red98C5's Avatar
    Jan 2008
    HEY....that is exactly what happened to me this Saturday when I tried to program my 2011 Corvette. The ECM went no problem but the TCM asked for a license number??? This was not the first time using the V2 but my tuner made an adjustment from my drag log files that day and told me to put the new program in. I had an unused Trans license so I had to agree to use a new one and lost one of my trans licenses because of it. What can I do??
    Sep 2012
    I just sent the .lbu to EFILive. We'll see what happens.
    Quote Originally Posted by Red98C5 View Post
    What can I do??
    Do what I explained in post #3.
    If your license backup file shows the controller is already licensed, then we'll issue a replacement VIN license free of charge.
    Jan 2008
    I will try to get the information tomorrow.
    Quote Originally Posted by JohnPShoe View Post
    The files that you sent to EFILive support clearly show that your controller is already licensed. The old firmware stored the license incorrectly in the FlashScan memory. The new firmware should (but does not) recognize the old/incorrect license. We'll issue a replacement VIN license. Please send your FlashScan serial number and auth code to me at paul@efilive.com
    See this page for details on how to obtain the serial and auth code:
    https://support.efilive.com/kb_artic...2143-YUOG-8049
    Lifetime Member samh_08's Avatar
    Oct 2008
    Paul, I have had the same issue multiple times with the latest firmware with BBX. FYI, when I hook up through a laptop, there is no problem.
    Quote Originally Posted by samh_08 View Post
    Hi Sam, do what Paul said in post #3 above.
  1. Updating V2 firmware/bootblock
    By -X- in forum FlashScan V2
    Last Post: November 14th, 2013, 01:20 PM
  2. Updating FlashScan V2 Firmware
    By Tordne in forum FlashScan V2
    Last Post: November 29th, 2011, 10:57 AM
  3. Having an issue updating Firmware
    By Leadfoot in forum FlashScan V2
    Last Post: December 7th, 2007, 05:20 PM
  4. Updating to BBL Firmware problems
    By WildChild in forum FlashScan V2 BB Logging
    Last Post: November 27th, 2007, 10:12 AM
  5. EFILive V2 Firmware Updating Instructions.
    By eboggs_jkvl in forum FlashScan V2
    Last Post: June 26th, 2007, 09:19 AM
