Results 1 to 4 of 4
Thread: RPM drops the instant VSS is detected
    Apr 2010
    Default RPM drops the instant VSS is detected
    Hi, I have an issue with my car stumbling as soon as I start to move and it appears to be triggered by vehicle speed. I did a test by sitting on a hill with it idling in gear and holding it with the handbrake to eliminate brake vacuum. The instant the VSS went above 0 the TB dropped from 16% back to 11% and the engine nearly stalled. I did nothing but released the handbrake. Could this only be caused by the throttle cracker or could it be a number of things? any help would be greatly appreciated. I have attached a short log and my tune.
    LQ4 TT 4l80e 235,235,114 cam
    Lifetime Member limited cv8r's Avatar
    May 2005
    Try this, couple of small changes. Might help.
    It's all good until it goes "Bang"
    Apr 2010
    Thanks mate, I will give it a go. Cheers
    MAP pid shows that to much air is getting in.
  1. Connection drops
    By mr.prick in forum General
    Last Post: November 26th, 2009, 08:50 AM
  2. Trans shifts with out meeting the commanded VSS and RPM
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 4th, 2008, 05:22 AM
  3. What is the difference between shifting VSS and RPM?
    Last Post: May 19th, 2008, 06:34 PM
  4. VSS v RPM HELP
    By alz28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 7th, 2008, 07:41 PM
