i changed VIN on an E78 before using the aborted v7.5 read trick. now when i try using v7.5 and select E78, when i try to start the read i get message that this is not supported controller type with v7.5. any suggestions?
Using the aborted read trick?
Just select "Clear DTC's" before changing the VIN, some of these late model ECM's need that done (E78, E92 etc)
like this, or some variant thereof: https://forum.efilive.com/showthread...n-12633238-E38
that didn't work.Just select "Clear DTC's" before changing the VIN, some of these late model ECM's need that done (E78, E92 etc)
So what happens? An error reported? VIN won't stick? Is the ECM in a car or on the bench?
Also, V7.5 does not read or flash the E78, you have to use the V8 software to do that. The E38 & E67 were probably the last CAN controllers to be added for read/write flash in V7. The new (current) generation of ECM's such as the E39, E78, E92 etc all must be read/flashed via V8.
bench. depends what strategy i use. won't stick if i clear DTCs and then change VIN, i can do that with V7.5. i can't read it with v7.5, although i am pretty sure that's how i did it successfully with an older version of v7.5 and it was definitely an E78. if i truncate the read w/ V8, i get $31 request out of range when attempting biderectional scanner V7.5 VIN change function. i tried different variations and either it errors or won't stick.
But if you get no reported errors then perhaps your battery +12V is missing on your bench set up? The ECM updates the VIN when IGN power is switched off (as if you turned the key off in the car), but Batt +12V must still be active, it actually takes about 20 seconds to fully shut itself down, this is when it updates the VIN as needed.
Not possible, E78 was never able to be read with V7.5.
no, it's correct. it's problem specific to certain ECMs only. it's similar obstruction in the late E38s in the thread i linked. aborting the read process is one way to circumvent it. at least that works with E38s.
maybe i didn't just use v7.5. i don't remember what i did exactly. but it was definitely an E78 and i used EFIlive. i'll try to figure out some other way to do it if i exhaust EFIlive options. where is the VIN change function in V8?Not possible, E78 was never able to be read with V7.5.
