Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 06 gmc envoy p12 pcm issue
    Lifetime Member HellKnightHicks's Avatar
    Mar 2011
    So I had the same thing happen to me. Im sitting in one right now it keeps flashing stablitrack off. I attempted to do a full reflash as sugested.
    Just keeps saying Stabilitrack is off in the cluster....
    So i powered off and tried again.
    Says Service Stabilitrack on the screen.
    Pulled fuse and it starts erases ECM and then begins flash. But EFI live
    EFI live repeats retrying previous block.....
    Mar 2011
    That was with V7 software i will try again with V8 software in a day or so.
    It was the latest version though... I had modified some DTC's is really the only reason i was in the tuning software... do you guys think that V7 is the reason for the flashing issue?
    Any help would be appreciated.
    Oct 2006
    I answered your PM. Never had an issue with the Stabilitrack causing an error before, you did right by pulling fuse I would think.
    Like I said in the PM the P12s are a strange breed, and can be temperamental some times.
    Again clear your Config files on the V2 controller and reinstall with the newer ones.
    2006 Trailblazer
    Mar 2011
    How do you clear the config files? I havent changed anything on the V2 controller.
    So you think i can salvage it then...? It did accept the boot loader.
    No it doesnt start.
    Oct 2006
    Go to "EFILive Explorer" with controller plugged into desktop/laptop, click on tab marked "F9: Config Files" and "Format Config", then close that and open EFILive Scan and Tune>F5: BBX and do the setup for P12 again> "Program", "Config file" gets rewritten. Try again.
    If there a faster way/less steps to do this, if anyone knows please post it here.
    As long as EFILive can see it it is probably recoverable with a "Full Flash", has to have complete OS before you can do "Calibration only".
    Bench Harness -- http://download.efilive.com/Tutorial...20Tutorial.pdf
    (EFILive Staff) On the Harness, if it denotes 4&8 on a pin out, that means 4 on the V2 to 8 on the PCM correct ?
    2006 Trailblazer
    Mar 2011
    Between the fuses and the config stuff that did it.
    Is there any way to load all of the config files using the SD card? Apparently my flash and scan couldn't handle the full load that's selected by default.
    Thx for the help
    No...
    "4 & 8" means: pins 4 and 8 on the same connector.
    Quote Originally Posted by HellKnightHicks View Post
    Thx for the help
    Not on the SD card...
    Delete any config files for ECM's that you do not use.
  9. #19
    Oct 2006
    No...
    "4 & 8" means: pins 4 and 8 o the same connector.
    Thanks joe.
    2006 Trailblazer
  10. #20
    Oct 2006
    Thx for the help
    No problem, we are all in this together. ;-)
    Those darn P12s can be a PITA.
    Oops forgot to tell you not to select all, there is a bar at the bottom that shows current percentage of space left it has to be under 100% obviously, you have to remove parameters to achieve that as you found out.
    2006 Trailblazer
  1. P12 PCM file
    By Chevy366 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: June 29th, 2009, 09:28 AM
  2. Part # for P12 PCM?
    By ScarabEpic22 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 30th, 2008, 05:32 PM
  3. Looking for PCM P/N for L21 454 (99 P12 RV Chassis)
    By N0DIH in forum Vortec V6/V8 Specific
    Last Post: August 20th, 2007, 04:54 PM
  4. Reading the P12 PCM
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: March 18th, 2007, 10:48 PM
