Go to "EFILive Explorer" with controller plugged into desktop/laptop, click on tab marked "F9: Config Files" and "Format Config", then close that and open EFILive Scan and Tune>F5: BBX and do the setup for P12 again> "Program", "Config file" gets rewritten. Try again.
If there a faster way/less steps to do this, if anyone knows please post it here.
As long as EFILive can see it it is probably recoverable with a "Full Flash", has to have complete OS before you can do "Calibration only".
Bench Harness -- http://download.efilive.com/Tutorial...20Tutorial.pdf
(EFILive Staff) On the Harness, if it denotes 4&8 on a pin out, that means 4 on the V2 to 8 on the PCM correct ?
