Thread: Max HP With Stock Injectors
    New Member rustynuts's Avatar
    Apr 2006
    Default Max HP With Stock Injectors
    at the risk of posting a newb question, i'd like to know what you guys think.
    what is the max hp you can SAFELY achieve with stock injectors? when i say safely, i'm referring to a vehicle that still tows long distances and may run the 1/4 mile now and again, but not often.
    yes i have searched but have gotten different answers. it seems efilive brings something new to the table. being able to control our dmax's with far greater precision. that said, what hp numbers are those with stock injectors putting out. assuming performace lift pumps cause i know the stock pump won't do much.
    CUSTOM FIBERGLASS HOODS FOR SALE
    http://pirate4x4.com/forum/showthread.php?t=824046
    '05 GMC 2500HD Duramax Crew Cab LT 4x4, EFILive, MBRP Exhaust w/ Cat Delete Pipe, 285 Revos, Bilsteins, Leveling Kit w/ Air Bags
    http://www.dieselplace.com/forum/gar...o=hall&u=20655
    '04 Hendrix Chassis, 4 Wheel Steer, LS1 Rock Crawler
    http://www.pirate4x4.com/forum/showt...ht=WHEEL+STEER
    EFILive Distributor Trippin's Avatar
    May 2004
    The LLYs have made around 470 RWHP with stock injectors.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Lifetime Member Max Power's Avatar
    Nov 2005
    They seem to be pretty reliable under 500hp. You should be able to get 450-470hp out of yours pretty easily and run that daily. That is what I run daily. You will need your transmission built up to hold that.
    09 LMM Duramax
    Apr 2006
    thanks guys.
    Lifetime Member bobo's Avatar
    Nov 2005
    I just had an LLY w/ all stock internals, injectors, turbo etc dyno at 488hp.
    Here is the dyno sheet. It was on a guy's truck I am tuning w/ EFI live. He has TTS lift pumps and a built trans.
    I also included some comparison runs of tunes I ran in my truck.
ID:	582   Click image for larger version.
Name:	bobvskennedy tq and hp.jpg
ID:	583   Click image for larger version.
ID:	584   Click image for larger version.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Jul 2005
    take a look at my last post here:
    http://redhardsupra.blogspot.com/
    play with the numbers, you'll be suprised/scared of some results
  1. LB7 Injectors
    By JustSomeGuy in forum Diesel
    Last Post: April 12th, 2010, 08:30 AM
  2. Low Imp Injectors/Changes
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: May 31st, 2008, 02:41 PM
  3. 42# injectors
    By vatman02 in forum Gen III V8 Specific
    Last Post: June 5th, 2007, 02:40 PM
  4. Injectors...
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2006, 03:11 AM
  5. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 03:14 PM
